Cam options for a 650?
- Tyler
05 Jun 2008 13:11
Other than original equipment what cam options are out there for the 650's. Can you run gpz cams or something like that, or are there aftermarket cams available? I had Delta cams do a regrind on my subaru, anyone have factory cam regrouns in a new profile? It would be cheap if anything.
"74 Yamaha DT 400 Enduro
- kxhonda
Re: Cam options for a 650?
05 Jun 2008 14:37
Check out this thread from not too long ago,
kzrider.com/index.php?option=com_kunena&...11355&catid=2#211355
Not too many people have run aftermarket grinds from web or megacycle in a 650 though, most people just run gpz750 cams even though you lose you tach.
1977 Kz650B1 #576th made.
Warsaw, In
Warsaw, In
- Tyler
05 Jun 2008 15:56
Thanks for the link, lots of info there... Hmmm looks like I have my homework assignment for the weekend.
I am planning on a 700 Wiesco overbore kit.
- steell
05 Jun 2008 17:31
Tyler wrote:
Isn't an 810 kit about the same price?
- anarki650
05 Jun 2008 18:25
Can you fit an 810 kit into 650 jugs? Or do you need to find those ever ellusive 1980 kz750 4 cylinder jugs to swap in and then punch over?
09 Kawasaki ER6n
77 kz650b1 cafe rebirth project
"Being shot out of a cannon will always be better than being squeezed out of a tube, that's why God made fast motorcycles..."
Dr. Hunter S. Thompson
Omaha NE
Omaha NE
- jordan
05 Jun 2008 19:40
ooh, just sold a pair of 1980 750 cylinders. Only went for $50, I was kinda disappointed.
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- kxhonda
05 Jun 2008 20:06
Some 81 cylinders have provisions for the rollers chain also, but not all. Prob a mid year change. Mine came from an 81.
Warsaw, In
Warsaw, In
- Voodoosoup
05 Jun 2008 20:34
anarki650 wrote:
I believe I read on here that you just need the 750 sleeves. You can have the original sleeves pressed out and replaced with the 750 sleeves.
- Tyler
05 Jun 2008 23:30
That seems odd. If the 750 sleeve will press in it has the same O.D. so that means it would have the same maximum bore diameter as a 650 sleeve.... Unless yuo have to cut the cylinders to press in the 750 sleeve. May be cheaper to get a 750 cylinder block.
