77 kz 650 cam caps
  • zippoman
  • zippoman's Avatar Topic Author
77 kz 650 cam caps
05 Feb 2006 16:55
#21737
I got some bad threads on one of my cam caps, what size helicoil do I need, is there much involved installing one? Thanks
  • wireman
  • wireman's Avatar
Re: 77 kz 650 cam caps
05 Feb 2006 18:36
#21756
take bolt to auto parts store with you and match threads.goodluck,happy wrenching!B)
  • APE Jay
  • APE Jay's Avatar
05 Feb 2006 21:47
#21795
No doubt 6 X 1 mm.
Jay
  • wiredgeorge
  • wiredgeorge's Avatar
06 Feb 2006 06:01
#21840
Your cam cap bolts are indeed 6mm with 1.00 pitch thread. If the thread is just a bit buggered, run a tap down; clean with solvent and blow the thread out with compressed air. If the thread is RUINED, then go oversize. You have a choice. If you don't care about metric vs SAE, 1/4" works fine as it is just slightly larger than 6mm. You could also go to 7mm if you don't mind looking for an odd size 7mm bolt. They can be found. Most racers replace stripped thread with 8mm bolts due to strength (8 x 1.25 insert). I suggest you consider buying Timesert or most any solid insert rather than fool with Helicoil as that product is a coil of steel that is hard to keep in the hole when you remove the bolt.
  • RonKZ650
  • RonKZ650's Avatar
06 Feb 2006 07:13
#21862
If you run bigger than 6mm will the bolt still fit through the dowell pins on the caps is the question. I doubt highly a 8mm would fit. Never used the timeserts, but the Helicoils I've done hundreds over the years and never have had problems with them. Some reason the exhaust caps on the KZ650 will always strip over time. I've done all my exhausts with Helicoils.
  • zippoman
06 Feb 2006 09:12
#21891
Ive never heard of a timesert, is it about the same? Thanks for the info, kevin
  • RomSpaceKnight
  • RomSpaceKnight's Avatar
06 Feb 2006 14:59
#21962
In my dragbike all cam cap bolts have been Helicoiled, just be on the safe side. Have had cams out repeatedly with never a problem.
  • baldy110
  • baldy110's Avatar
06 Feb 2006 16:36
#21989
Helicoil it. I had my head off a few years ago and just helicoiled all the cam caps just so I wouldn't have to deal with them while on the bike.
With cams that have to be removed to change valve clearances you would have thought Kawasaki would have installed inserts from the factory. I can't tell you how many of these things I have stripped out over the years.
Oh yeah they are 6mm x 1.0. Good luck
