Oil Cooler Lines - Help/Advice Needed
- Ilbikes
31 May 2008 17:45 #217010
by Ilbikes
Oil Cooler Lines - Help/Advice Needed was created by Ilbikes
Guys, I've now have the cooler (settled on a polished B&M Supercooler 4.5"x11"x1.5" - $55) and I've just won a set of NOS fittings on EBay. Now for the lines. I'm new to the four stroke Kaws, can some of you post photos of bikes with coolers and lines? I want to see how they are run and routed -
Help/input greatly appreciated.
Gordon
Gordon
- Bullitt03737
31 May 2008 18:15 #217015
by Bullitt03737
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
Replied by Bullitt03737 on topic Oil Cooler Lines - Help/Advice Needed
Im going to be following your thread very closely. where did you get your cooler at?
- Ilbikes
31 May 2008 20:50 - 31 May 2008 20:52 #217029
by Ilbikes
Replied by Ilbikes on topic Oil Cooler Lines - Help/Advice Needed
Right here -
store.summitracing.com/partdetail.asp?au...221+115&autoview=sku
Here is a photo of my Honda and it's 11"x5"x1" cooler. I found this B&M a few days back.
Last edit: 31 May 2008 20:52 by Ilbikes.
- Ilbikes
31 May 2008 20:51 #217030
by Ilbikes
- Z1109R Fin
- Thank you received: 1
02 Jun 2008 03:57 #217315
by Z1109R Fin
Z1000R ´83...Slightly modified...
Replied by Z1109R Fin on topic Oil Cooler Lines - Help/Advice Needed
- BSKZ650
- Thank you received: 14
02 Jun 2008 04:59 #217323
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic Oil Cooler Lines - Help/Advice Needed
mine run up under the tank, th PO installed the cooler, I have never had any issues with it at all, I will try to get a pick later
- rstnick
- Thank you received: 377
02 Jun 2008 06:39 #217350
by rstnick
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
Replied by rstnick on topic Oil Cooler Lines - Help/Advice Needed
Mine ran down the frame tubes and under the engine as the connections were on the bottom in my case.
It depends on what engine your dealing with.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- Ilbikes
02 Jun 2008 09:49 #217401
by Ilbikes
Thanks guys - keep them coming. I would like to see all of the options out there.
Thanks,
Gordon
Thanks,
Gordon
- Z1109R Fin
03 Jun 2008 03:10 #217560
by Z1109R Fin
One thing to consider is of course the connections. That´s pretty important. And of course heat issue. Routing lines over the engine (as they are in stock ELR)could mean less effective cooling.
- Ilbikes
03 Jun 2008 08:25 #217617
by Ilbikes
Actually this will be a challenge I look forward to. I plan to have an attractive grill made for the cooler and I'll need to come up with a nice rubberized clamp system to go around the downtubes (like I did on the CB750 above). I think I want to go stealth with the lines and run them up and over the engine - then down between the carbs to the fittings behind the cylinders. I will likely use stainless tubing custom bent for the feed and return lines. These should blend into the engine color and be mostly hidden by the fuel tank when run above the cylinder head/cover. I'm not worried about the engine heat - if it doesn't ignite rubber fuel lines and gasoline, it sure won't bother the oil in the lines.
The radiator core is responsible for the heat exchange - I'm confident they work. The Honda has not let it's oil exceed 190 to date - even after some hard rides, 10.5:1 compression and summer heat. The Honda has the disadvantage of having it's lines run in parallel to the Kerker header pipes, but since the oil fiter and cooling adapter is front and center of the case - I really had little choice.
More ideas, please -
Gordon
Gordon
- Tyler
- Thank you received: 92
03 Jun 2008 10:48 #217650
by Tyler
"74 Yamaha DT 400 Enduro
Replied by Tyler on topic Oil Cooler Lines - Help/Advice Needed
Do you guys install a check valve when you add these coolers to keep the oil from draining back?
- galaxian
03 Jun 2008 12:58 #217682
by galaxian
1977 KZ1000A1, 1979 KZ650 C3
Replied by galaxian on topic Oil Cooler Lines - Help/Advice Needed
Can someone post exact lengths of lines and what fittings they are using?
