Am I screwed?
- ericvm
Am I screwed?
31 May 2008 03:25
Ok...so I was feeling proud about my first top end re-build when I discovered a couple peices I failed to install. They are the pins in the oil passage between the cylinder block and head. I did put the o-rings in though. Will I get oil up to the top without these? Can I count on a massive oil leak all over the fins? What kind of trouble am I in?
\'82 Gpz 750 (KZ 750 R)
- ericvm
Re: Am I screwed?
31 May 2008 03:27
92043A is the part I didn't put in.
- steell
Re: Am I screwed?
31 May 2008 06:24
If you don't remove the head and install those oil restrictors you stand a good chance of wiping out the bottom end.
- bountyhunter
Re: Am I screwed?
31 May 2008 12:36 - 31 May 2008 12:37
steell wrote:
BTW: I think the 92043 is just an alignment pin.
Yep, and the reason is: if that's like my bike, that "flow pin" is also a flow restrictor (orifice). In other words, it has a small restrictive hole in it. That raises back pressure againt oil flow coming off the pump from down below. Without restricting it, the system oil pressure will drop and oil won't be flowing to all the other places like it normally should. That starves oil to critical places like main bearings and such.If you don't remove the head and install those oil restrictors you stand a good chance of wiping out the bottom end.
Last edit: 31 May 2008 12:37 by bountyhunter.
- ericvm
Re: Am I screwed?
31 May 2008 16:56
Thanks. I've now removed the head and am waiting on a new $37 head gasket. Damn.
- bountyhunter
Re: Am I screwed?
31 May 2008 21:53 - 31 May 2008 21:54
ericvm wrote:
Was it a new head gasket for the rebuild that has not been run (just torqued down?)
If so, I'd use that sucker again. It will need re torquing anyway after the first run. Worked on mine.
Last edit: 31 May 2008 21:54 by bountyhunter.
- Sandy
- Fly High,Tony
Re: Am I screwed?
01 Jun 2008 20:25
Yes,if the head gasket was only torqued into place...I too would reuse it,for sure!
1977 KZ1000 A-1
- ericvm
Re: Am I screwed?
01 Jun 2008 20:58
during assembly I used gasket sealant around the two outer crankcase bolts on each side ...just like the manual said to
When I took the head off again, the gasket tore apart where the sealant was used.
- Sandy
- Fly High,Tony
- bountyhunter
Re: Am I screwed?
01 Jun 2008 22:59 - 01 Jun 2008 23:02
ericvm wrote:
Double bummer. But, at least you didn't run it and mess up the engine and you learned a lesson. That's not as bad as the train wreck when I did my rebuild: the new cylinder base gasket disintegrated in about 100 miles and I had to tear it all the way down to the rods and do it all over.
Last edit: 01 Jun 2008 23:02 by bountyhunter.
- ericvm
Re: Am I screwed?
02 Jun 2008 08:36
was there something wrong with your base gasket? Why did it disintegrate?
- Sandy
- Fly High,Tony
Re: Am I screwed?
02 Jun 2008 08:42
ericvm wrote:
Ya,Bountyhunter...wth?
What caused it to fail so prematurely?:huh:
1977 KZ1000 A-1
