Am I screwed?
31 May 2008 03:25 #216914 by ericvm
Am I screwed? was created by ericvm
Ok...so I was feeling proud about my first top end re-build when I discovered a couple peices I failed to install. They are the pins in the oil passage between the cylinder block and head. I did put the o-rings in though. Will I get oil up to the top without these? Can I count on a massive oil leak all over the fins? What kind of trouble am I in?
\'82 Gpz 750 (KZ 750 R)
31 May 2008 03:27 #216915 by ericvm
Replied by ericvm on topic Am I screwed?
92043A is the part I didn't put in.
31 May 2008 06:24 #216925 by steell
Replied by steell on topic Am I screwed?
If you don't remove the head and install those oil restrictors you stand a good chance of wiping out the bottom end.
31 May 2008 12:36 - 31 May 2008 12:37 #216965 by bountyhunter
Replied by bountyhunter on topic Am I screwed?
Yep, and the reason is: if that's like my bike, that "flow pin" is also a flow restrictor (orifice). In other words, it has a small restrictive hole in it. That raises back pressure againt oil flow coming off the pump from down below. Without restricting it, the system oil pressure will drop and oil won't be flowing to all the other places like it normally should. That starves oil to critical places like main bearings and such.
BTW: I think the 92043 is just an alignment pin.
Last edit: 31 May 2008 12:37 by bountyhunter.
31 May 2008 16:56 #217002 by ericvm
Thanks. I've now removed the head and am waiting on a new $37 head gasket. Damn.
31 May 2008 21:53 - 31 May 2008 21:54 #217042 by bountyhunter
Was it a new head gasket for the rebuild that has not been run (just torqued down?)
If so, I'd use that sucker again. It will need re torquing anyway after the first run. Worked on mine.
Last edit: 31 May 2008 21:54 by bountyhunter.
01 Jun 2008 20:25 #217280 by Sandy
Replied by Sandy on topic Am I screwed?
Yes,if the head gasket was only torqued into place...I too would reuse it,for sure!
1977 KZ1000 A-1
01 Jun 2008 20:58 #217286 by ericvm
during assembly I used gasket sealant around the two outer crankcase bolts on each side ...just like the manual said to
When I took the head off again, the gasket tore apart where the sealant was used.
01 Jun 2008 21:11 #217290 by Sandy
Bummer.:(
1977 KZ1000 A-1
01 Jun 2008 22:59 - 01 Jun 2008 23:02 #217300 by bountyhunter
Double bummer. But, at least you didn't run it and mess up the engine and you learned a lesson. That's not as bad as the train wreck when I did my rebuild: the new cylinder base gasket disintegrated in about 100 miles and I had to tear it all the way down to the rods and do it all over.
Last edit: 01 Jun 2008 23:02 by bountyhunter.
02 Jun 2008 08:36 #217376 by ericvm
was there something wrong with your base gasket? Why did it disintegrate?
02 Jun 2008 08:42 #217380 by Sandy
Ya,Bountyhunter...wth?
What caused it to fail so prematurely?:huh:
1977 KZ1000 A-1
