Oil plug strip - Where to find overzise bolt?
- jcote75
28 May 2008 20:49
Hi,
Seem like the easiest way to fix this is to have an oversize thread. Is this correct?
I've searching localy and seem like nobody can help me......
Can somebody give a link to where I can find theses....
Or provide another good solution.
Thanks in advance,
Joce
Thanks in advance,
Joce
- donthekawguy
Re: Oil plug strip - Where to find overzise bolt?
28 May 2008 23:07
Depending on the bike (a hint to put your model in your signature line) the oil pan is an easy change. On the 900's and 1000's you can drop the pan and replace real easy. The hardest part is scraping the old gasket off.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
1971 Kawasaki g3ss
1972 Yamaha R5 350
1964 Yamaha 125
- jcote75
29 May 2008 06:23
Oups. signature has disapear.............
It's for the 1984 KZ1100R.
An oil pan form a J motor or a GPZ1100B2 is not the same.
This motor is from the 1984 GPZ1100 and parts are hard to find and don't want to take the risk that the tread is also damage....
Any good solution?
Any good solution?
- coppertales
29 May 2008 07:54
You might get lucky and find a pan on ebay reasonable. Otherwise, pull the pan and have a machine shop install an insert that will replace the threads.....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
1982 1100 SPECTRE
- jcote75
29 May 2008 08:18
I'll check ebay for sure.
Meantime, I put some locktit on the tread but I'm way far from the correct torque.
Is it safe to ride this way or I should leave the bike (answer my question here....:S )
29 May 2008 10:07
Could do a search in the above Search Forum box (located in the grey ribbon toward the righthand side) by typing oil plug oversize inside the box and click on Go. Should return several earlier threads containing much helpful information. Just scroll down to locate those most applicable.
Seems the self-tapping oversize plugs are available at auto parts stores. Among other various remedies, some folks are using helicoil or threadsert repairs.
Good Luck!
Good Luck!
- 76 LTD
29 May 2008 15:36
Take your old plug to just about any good auto parts store and they should have an oversized self tapping plug that will work.
- JR
29 May 2008 17:10 - 29 May 2008 17:14
Canadian Tire
Bring your old one with you. parts diagrams at www.kawasaki.com might have dimensions. Canadian Tire will have a rack or a shelf with a selection of them on full display in the auto section. They will have oversize self tapping. Not expensive.
Thats where I got mine :woohoo:
I would'nt ride the bike with a plug that could fall out and spill oil where your back wheel is about to go. Worst case you can get whats called an emergency or temporary plug at Canadian Tire.
Good luck
Good luck
Last edit: 29 May 2008 17:14 by JR.
- jcote75
29 May 2008 20:07
Thanks everyone
I'll try at Canadian tire first
Joce
Joce
- JMKZHI
Last edit: 04 Dec 2008 06:37 by JMKZHI.
