Valve cover leak on a '82 KZ750 E
- Ituen
- Rider
28 May 2008 13:02
Is it difficult to change the valve cover gasket on an '82 KZ750 E (4 cyl)? While I have the cover off is there anything I can do to the bike to increase it's performance?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
Re: Valve cover leak on a '82 KZ750 E
28 May 2008 13:22
Ituen wrote:
Would check valve clearances.
Not difficult to replace the valve cover gasket. Sometimes it takes a while to painstakenly remove all remants of the old gasket from the cover and the head without damaging either's mating surface. Would also consider replacing the half-moon plugs, and applying a light coat of silicone adhesive on the plugs during reassembly.
Imo, best to not use any sealant on either side of the new gasket. And don't use Godzilla force when tightening the valve cover screws. I like to use a criss-cross tightening pattern starting with the inside bolts, first snug, then repeat pattern to final snugness.
Good Luck!
Good Luck!
- bountyhunter
28 May 2008 15:38 - 28 May 2008 15:39
Patton wrote:
The proper tightening pattern is in the factory service manual for the cover.
I agree about over cranking the bolts, and in my manual they spec the torque at about 100 inch-lbs and I recommend a lot less like maybe 60% of that.And don't use Godzilla force when tightening the valve cover screws. I like to use a criss-cross tightening pattern starting with the inside bolts, first snug, then repeat pattern to final snugness.
Good Luck!
Last edit: 28 May 2008 15:39 by bountyhunter.
- JR
28 May 2008 17:45
Not difficult at all to change take off the valve cover.
Take off the gastank
Remove all the bolts.
You will probably have to take off the coils.
You might have to remove the carbs.
There;s not a lot of room between the valve cover and the frame so you have to wiggle the cover around.
Like the guys above say, take your time removing old gasket, check the valve clearances and dont overtighten the bolts when you replace them.
Last time I had my cover off I replaced the bolts with stainless allen head bolts.
- tool maker
28 May 2008 18:41
Be sure to remove the cam chain tensioner, as not to damage anything when you reassemble the valve cover.
Lancaster, PA
82 KZ1000 M2, stage 3 jet kit, pods, 4 into 1 Mac, Accel coils & wires.
