trueing,welding, and balancing the crank
  • FastKaw1
  • FastKaw1's Avatar
Re: trueing,welding, and balancing the crank
28 May 2008 17:42
#216479
OK
In the old days they used to weld a crank with a bent rod.
(stick welding) You can weld, so weld it if you like.
You do not add that much steel at the weld points to through
a crank out of balance. You are only adding a 1/2 to 3/4 inch long
X1/4 wide weld to the crank center not on the out side edge.
It's not going to through the crank out that much.
Find a markII crank and go..... It's a much better then a Z1 crank.
If you can't find one, PM me I think I know were there is one setting.
XENU
  • steell
  • steell's Avatar
28 May 2008 17:45
#216481
captscubaman wrote:
Anybody out there with knowlegde of American Turbo Pac kit install and set up?
Wow! An "Out of the blue" thread hijack!:woohoo:
  • sully73
  • sully73's Avatar Topic Author
  • throttle till you see GOD, then brake.
28 May 2008 18:13
#216485
how much for the mark crank xenu? and if i pick up a mark, dont i have to get a new timing chain length? i know its a better crank, but for what im wanting out of this bike, i think a stock one will be fine. thanks for the offer tho, but if the price is right id surely be interested.
btw, what the hell was up with the ninja post?
81 kz1000 ltd
72 cb750 chop
  • captscubaman
  • captscubaman's Avatar
28 May 2008 19:27
#216503
Forgive me if I have offended anyone. I am new here and I am not familiar with the forum. Could use a little help. What is a thread hijack? Thank You
  • captscubaman
28 May 2008 19:33
#216504
Just read the rules and realize I need to start a new thread. Again sorry for the mistake
  • FastKaw1
  • FastKaw1's Avatar
28 May 2008 20:43
#216514
sully73:
Yes you will need a new cam chain for a 16 tooth crank sprocket,
Regardless, if you change the crank you should change the chain.
Cost??? Do /will you need the stater magnet? I will ask a friend I think he has one.
A (guess) $250 unknown if welded or not. I have no idea what is a good price.
I haven't needed one in 10 years. (Ebay) maybe Im sure he is going to say
how much are you willing to pay. Or how bad do you need it.
We all know how it all works. Please take no offense.
Best I can tell you on cost is see what some of the other posters here say.
XENU
  • FastKaw1
  • FastKaw1's Avatar
28 May 2008 20:49
#216516
Don't sweat it. We all have dun one time or a other.
Im not a good one to answer turbos?
Not dependable enough for my taste...
XENU
  • 893cv
  • 893cv's Avatar
28 May 2008 22:02
#216530
There is no way to cheeply put a MKII crank in a J engine. You will have to find a J crank to replace yours.
1980 kz1000 LTD
1978 Z1R
  • Makarth
  • Makarth's Avatar
28 May 2008 23:11
#216538
you know i was thinking if he had access to a press could he make a rough guesstimate to true the crank if he really needed to?
1977 kz1000 - Megasquirt project @ 40% wiring, plenum, and exhaust<--(done!)
  • donthekawguy
  • donthekawguy's Avatar
28 May 2008 23:28
#216542
I think APE's kzzone.com has pics of the welds on a crank. There is a J crank on ebay right now. I also have a local dragrace guy that had a J motor he wanted to sell me for $200 last summer. I can check with him and see if he still has it. If you want we can go halves on it. I just wanted the head and you can have the rest. PM me.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • FastKaw1
  • FastKaw1's Avatar
29 May 2008 05:30
#216561
CRAPPPPPP
I mist the J modal part.
I stand corrected.
XENU
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
29 May 2008 07:13
#216577
tig,heli-arc same deal.This process was perfected in 1941, and became known as heliarc or tungsten inert gas welding, because it utilized a tungsten electrode and helium as a shielding gas.
you will be fine with a stock crank unwelded,for what you want.so get the best deal you can and keep moving. my.02
