vance n hines no baffle?
  • NickW900LTD
  • NickW900LTD's Avatar Topic Author
  • Nick
25 May 2008 14:07
#215720
does anyone run open header? I know its loud, but will it hurt the motor?
1976 KZ900 LTD (sold)
1977 KZ1000 LTD
1978 KZ1000 A2A
Pierceton, Indiana USA
  • 76 LTD
  • 76 LTD's Avatar
Re: vance n hines no baffle?
25 May 2008 16:07
#215736
Wont hurt the motor as long as carbs are jetted properly.might hurt your pocket book tho.most cops dont like loud pipes.
  • NickW900LTD
  • Nick
25 May 2008 22:35
#215848
not nearly as loud as most harley d's around here, i think im running 122.5 mains in my 29 smooth bores, doesn seem to hurt the performance.
1977 KZ1000 LTD
1978 KZ1000 A2A
  • jordan
  • jordan's Avatar
25 May 2008 22:39
#215851
I always leave my baffle out. I like the sound and it seems to run the same if not better
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold :(
1972 Kawasaki s2 350-parted on ebay :(
1973 Kawasaki s2 350-parted on ebay :(
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
  • NickW900LTD
  • Nick
26 May 2008 10:14
#215945
ok, My set up is 29mm smoothbores w/17.5 pilots and 125 mains. I rode 15 miles today without the baffle and did a plug check. The plugs looked dark gray, but nothing too sooty. The bike pulled hard through all the gears to the redline. A little shakey under mid range, but after 3k it took off and on the highway it ran great. Can somone assure me that the open header will not cause valve damage. I hear 2 sides all the time that it wont hurt them and from other that it will.
Nick
1977 KZ1000 LTD
1978 KZ1000 A2A
  • racer54
  • racer54's Avatar
26 May 2008 11:42
#215958
It won't hurt the valves. Only way I know of hurting valves would be if you ran the motor without the header and then you would probably burn your exhaust valves. No header lets the cool outside air hit the hot exhaust valves and can do a number on the valves. Other than that, I see no reason to worry about running an open header on your bike...aside from the obvious noise factor. Whenever you are in a situation where the noise may be an issue...i.e. passing a police officer, etc....just get off the throttle and pass him while the motor is at a idle and once you are a little way pass him, throttle up gently as not to attract his attention.
