KZ750 twin.....Soo slow.
- bountyhunter
Re: KZ750 twin.....Soo slow.
25 May 2008 18:17 - 25 May 2008 18:19
superboosted wrote:
Yes, 180 off will spark at bottom dead center of both stroke cycles of the pistons. Correct spark is at TDC of both strokes.so just trial and error?It WOULD still have spark,correct?
Last edit: 25 May 2008 18:19 by bountyhunter.
- superboosted
- not new to motors/but surely new to this one!
25 May 2008 19:41
1 plug looks good...one is black,and smells of gas.
I have checked and they both get spark,and did the water test to both pipes.
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
- superboosted
25 May 2008 19:48
How much resistance should the wire cap have?And what should the plugs be gapped at?
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
- superboosted
25 May 2008 19:52
4.57 ohm
4.40 ohm
resistance on the boots
4.40 ohm
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
- superboosted
25 May 2008 22:37
Well....Just by chance I cleaned the carbs(again)and when I was removing the main jets,one was full of junk!It wont come out though as the flathead side is boogered pretty good.
...so I guess I will look for a bowl,and a jet on tuesday.
77\\\\\\\'KZ750B
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
80\\\\\\\'CB750K
76\\\\\\\'BMW R75/6
- bountyhunter
26 May 2008 12:43 - 26 May 2008 12:45
superboosted wrote:
If you clean the bowl and jet thoroughly, you might not have to remove the jet.
Good luck. BTW, nobody sells the main jets for the Mikuni BS38 carbs as a part, but you can get them in the Keyster rebuild kits. Only the stock size (125) is available.Well....Just by chance I cleaned the carbs(again)and when I was removing the main jets,one was full of junk!It wont come out though as the flathead side is boogered pretty good.
Last edit: 26 May 2008 12:45 by bountyhunter.
