How high can you spin a '82 KZ 750?
- Ituen
- Rider
24 May 2008 05:27
What rpm should I shift at on my '82 KZ 750?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- Beatpoet
Re: How high can you spin a '82 KZ 750?
24 May 2008 07:16
You should shift at the point where it makes more power to be in the next gear :blink:
- bountyhunter
24 May 2008 15:06
Ituen wrote:
Beofre you get to the redline on the face of the tachometer.
- Bluemeanie
24 May 2008 15:36
If your talking about winding it out you would want to shift at the RPM where maximum torque is produced. My bike's redline is 9500 but max torque is I believe 8-8500.
- Ituen
- Rider
24 May 2008 19:44
I've been shifting around 6-6500 RPM. Where's the maximum torque for the 750 (738cc) motor?
1982 KZ750 E
Kawasaki Rider
Kawasaki Rider
- steell
24 May 2008 23:02 - 24 May 2008 23:12Maximum Torque 6.4 kg-m at 7500 rpm
zedder.com/Info/82%20KZ750-E3.htm
Although I think you would want to wind it high enough to where you would be at that rpm after you shifted for maximum acceleration.
But if you are talking about normal street riding, why would you want to use max acceleration all the time? I shift my 750 twin at 3k rpm or so, that gives me sufficient acceleration to out run the cars, and it will make the motor last a whole lot longer. Plus it gets really good fuel mileage doing that
And I don't use full throttle.
Last edit: 24 May 2008 23:12 by steell.
