- Thank you received: 12
kz 400 engine gasket kit
- oldkaws4ever
- Have no regrets...... You only live once.
22 May 2008 03:16 #215048
by oldkaws4ever
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
kz 400 engine gasket kit was created by oldkaws4ever
im taking my 1976 kz 400 apart to freshen her up, paint the fraim, polishe the engine, rebuild the carbs.....etc. I was wondering if there was a engine gasket set for the kz 400 avalable anywere, because it has a slight head gasket leak, whitch i heard was a defect from the factory. Or would i be better off going to autozone and getting the gasket paper and making my own, using the old ones as templates?
76 Kz 400d
05 ninja zx-636
81 Kz 750 Ltd
Darien, Illinois
- bountyhunter
- Thank you received: 337
22 May 2008 15:20 - 22 May 2008 15:33 #215171
by bountyhunter
Replied by bountyhunter on topic kz 400 engine gasket kit
Look for a gasket set from vesrah or athena. Old Bike Barn is a good place to start. Do a search on "KZ 400 top end gasket set".
You can NOT make your own head gasket, but most of the other gaskets are OK with typical gasket material.
I found this one on ebay:
cgi.ebay.ca/kawasaki-kz400-complete-oem-...100443QQcmdZViewItem
Last edit: 22 May 2008 15:33 by bountyhunter.
