- Thank you received: 1
Engine Noise
- 76 LTD
20 May 2008 19:26 #214846
by 76 LTD
Engine Noise was created by 76 LTD
My 79 1000 has developed a clattering noise that seems to be coming from the area of the stator cover.starter clutch maybe? or loose rotor? anyone had the same problem or any ideas. Thanks
- coppertales
21 May 2008 08:41 #214916
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Replied by coppertales on topic Engine Noise
Does the engine rattle at idle then go away around 1500 rpm or so? I had one like that which ended up being loose starter clutch bolts. To find out for sure, pull your stator cover and reach behind the rotor and see if you can move or feel any looseness in the starter clutch. If it moves, it is loose. That would also be a good time to change the rollers and springs too....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- 76 LTD
21 May 2008 16:20 #214980
by 76 LTD
Replied by 76 LTD on topic Engine Noise
Thats pretty much what its doing but the noise never completely stops.im thinkig of deleting the electric start altogether.
- coppertales
22 May 2008 08:01 #215104
by coppertales
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
Pull your stator cover off and have a looksee. Remember to gasket goop your rubber bushing where the wires exit the cover or it will leak oil all over your shoe......Permatex no 2, the black sticky stuff works the best. chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
- TeK9iNe
- What did you do!?!
- Thank you received: 28
25 May 2008 12:00 #215704
by TeK9iNe
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
Replied by TeK9iNe on topic Engine Noise
Hey "76 LTD", Got any more info on the fix for this? Sounds like my bike is doing the exact same thing - the sound is horrible!
Cheers!
Cheers!
79 Kawie Z1000 LTD
81 Kawie Z1000 CSR
83 Honda VT750C A
85 Kawie GPZ900 A2
86 Zukie GS1150 EG
93 Yamie XV1100 E
