1213cc kit in KZ900 - 76.5mm piston rings needed
  • Sorf
  • Sorf's Avatar Topic Author
20 May 2008 02:06 - 20 May 2008 02:08
#214680
G'day all,
Know of a fella over here in Oz, has just pulled down his Z9 and found it has a belly full of 76.5mm pistons. Only thing is it needs new rings. Anyone have any info on a bore kit of this size or where to source rings for it???
Thanks
Last edit: 20 May 2008 02:08 by Sorf.
  • PLUMMEN
  • PLUMMEN's Avatar
Re: 1213cc kit in KZ900 - 76.5mm piston rings needed
20 May 2008 08:14
#214729
who made the piston kit?;)
  • APE Jay
  • APE Jay's Avatar
20 May 2008 14:06
#214783
Have a feeling he is measuring it wrong. or someon had some customs done to repair a worn out 1200 kit.
Jay
  • Sorf
21 May 2008 03:25
#214886
Information since my post.....Pistons have RC ENG stamped underneath............and yes it's been measured right.
  • APE Jay
  • APE Jay's Avatar
21 May 2008 14:27
#214962
Back in those days, the rings came from oem applications. 75 mm was Yamaha 650 twin, so 76 was same, step 4. Don't know where you would find 76.5.
There may have been a 76 from an early Honda Civic, so you would use the step 2 version of that.
List the ring groove widths, and we will see what matches up.
Jay
  • Sorf
23 May 2008 06:23
#215284
Thanks Jay,
Another piece of the puzzle:
thanks all for your efforts,the ring grooves are 1.5 mm for the two top and 3 for the oil, i want to stay with the kit i have as the pistons are in really good condition, ive been searching but so far i have only come close to the right size,im beginning to think that i may have to settle for close and then modify,an interesting thing about these pistons are that they have a machined alloy plug that fits in either side of the gudgeon pin acting as a retainer,i have never seen this before has anyone else
M
  • steell
  • steell's Avatar
23 May 2008 12:15 - 23 May 2008 12:17
#215351
They are normally called "buttons", and have been made of both aluminum and teflon.
Normally used in racing motors.
Owner a Brit? That's the only place I know that calls a wrist pin a "gudgeon pin" :)
Last edit: 23 May 2008 12:17 by steell.
  • Old Man Rock
  • Old Man Rock's Avatar
24 May 2008 06:42
#215510
Follow the link to APE piston kits....
kzzone.com/pistons.html
These guys are really good and have decent prices.
Old Man Rock
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
  • APE Jay
  • APE Jay's Avatar
24 May 2008 10:17
#215529
1.5, 1.5, 3.0 is an XN ring. E-mail Wiseco and JE Pistons and ask them if they have 76.5XN rings available.
Jay
