i want lower compression
  • School Teacher
  • School Teacher's Avatar Topic Author
19 May 2008 21:11
#214655
ok i got some 12.5 to 1 pistons(1197) and wanna have premium gas run in it not jet fuel. any way i have a ported head(needs some repair work) with some 410 cams. how to get the compression down around 10-1. do i go with a gpz head... or a gasket on the base with the head i have? where are the problems with these options.
thanks guys
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
  • saxjonz
  • saxjonz's Avatar
  • KawboyZ
Re: i want lower compression
19 May 2008 21:15
#214656
Well I would go for the gpz head for sure. Maybe a bit more money but it will drop the compression and you will have a better head plus I think they have bigger valves but then again I have been told that you could shave the pistons if they are the wiseco as they have plenty of meat. I don't know the specifics but I would get the gpz head.
79 LTD B3
  • bountyhunter
  • bountyhunter's Avatar
19 May 2008 22:00
#214661
First thing I thought of was shaving the top of the pots. Could also mill out the inside of the combustion chamber a shade.
  • FastKaw1
  • FastKaw1's Avatar
20 May 2008 05:56
#214699
Pull the head. Are the pistons level with the top of the head?
You can do two things. Pull the block and add extra base gasket, that will drop
your compression. (Puts the pistons further in the hole)
That is what I would do. Most coast effective.
Or you can pull the pistons and shave the tops off.
If you send the head out to have the combustion chamber reshaped for lower com. IT will only reck a perfectly good head
XENU
  • coppertales
  • coppertales's Avatar
20 May 2008 08:33
#214732
I second the suggestion to add another base gasket....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
  • bountyhunter
20 May 2008 12:58
#214771
How much effect does that have? I recall the gaskets in my rebuild set were only about .030" thick and probably compress to maybe half that thick under the head torque bearing straight down on the base gasket. I was just wondering how much it would actually drop the compression to add a second gasket.
  • FastKaw1
  • FastKaw1's Avatar
20 May 2008 15:12
#214788
It's bin 30yr. sines I figured this out. boy I hate to say that.
APEgeroge might be a better source.
A stock gasket is .030 Get a copper or alum. around .060 that will put the piston
.030 in the hole. and if I remember correctly 10-12% lower comp.
Make sure you use a good gasket sealer on copper gaskets.
You can stack two .030 to get .060 or any combination.
You wont to worry about valve to piston anymore.
Hope this helps
XENU
  • FastKaw1
  • FastKaw1's Avatar
20 May 2008 15:26
#214790
OPPS Sorry
APE JAY
  • School Teacher
20 May 2008 17:14
#214814
its not put together yet.
but thanks on the suggestions sounds like i could go either way.
1980 kz1000G1
  • bountyhunter
21 May 2008 12:49
#214952
Interesting, I wouldn't have guessed that much.
  • bountyhunter
21 May 2008 12:54 - 21 May 2008 12:57
#214953
FYI, there is a source for actual octane booster that WORKS because it contains tetraethyl lead. You can easily jack your octane up ten points if you want. It's called:
Octane Supreme 130
www.batterystuff.com/fuel-treatments/OS6q.html
www.kemcooil.com/specials.php
You can't use it if your bike has a catalytic converter, otherwise OK. I use it on mine.
The stuff they sell at Pep Boys or Kragens only raises it a very small amount because they can't put lead in it. It's pretty useless.
Last edit: 21 May 2008 12:57 by bountyhunter.
  • APE Jay
  • APE Jay's Avatar
21 May 2008 14:23
#214961
By compression, I assume you mean cylinder pressure. You could start by moving the exhaust cam to give them more overlap. That will bleed off cylinder pressure.
Jay
