Any of you long time mechanics....
19 May 2008 08:10 #214528 by coppertales
Any of you long time mechanics.... was created by coppertales
know of a way to soften baked on 25 year old gaskets? I have been trying to remove the old base gasket on my 82 1100 and it eats razor blades by the dozen. I have been wrenching a long time and I have never seen this before.....thanks....chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
19 May 2008 08:26 - 19 May 2008 08:27 #214531 by Saki Jockey
Replied by Saki Jockey on topic Any of you long time mechanics....
www.permatex.com/products/automotive/aut...x_Gasket_Remover.htm
Careful when using it around painted surfaces, it's tough on paint too.
Rob A.
550 A4
GTA,
Ontario, Canada
Last edit: 19 May 2008 08:27 by Saki Jockey.
19 May 2008 08:31 #214533 by steell
Replied by steell on topic Any of you long time mechanics....
I know what you mean :woohoo:
I don't know what Kawasaki uses for those gaskets, but if they made car bodies out of it they'd last forever :D
Anything abrasive enough to cut that stuff also cuts the aluminum. Tried the spray gasket remover and it causes instant rust on rods/etc.
Buying razor blades by the case is the only solution that I have found.
19 May 2008 08:53 #214536 by mariozappa
Replied by mariozappa on topic Any of you long time mechanics....
I buy something called Aircraft Stripper in the automotive section at wal-mart.
Spray it onto a piece of cardboard (foamy stuff) and take a brush and spread it on the gasket area.
In about 15 minutes (above 70 degrees) it should be a lot easier to remove.
1977 KZ650C1
and the KZ650/KZ750 Conversion ;)
19 May 2008 09:48 #214544 by coppertales
Replied by coppertales on topic Any of you long time mechanics....
Thanks guys......I will hit walmart on the way home tonight. The bike is ready to go back together except for this gasket removal......chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
19 May 2008 09:55 #214545 by neo02blue
Replied by neo02blue on topic Any of you long time mechanics....
I have tried the off the shelf gasket removers.
They didn't seem to work all that great. I saw it in another thread that paint remover works just as well.
I had a few stubborn gaskets that I soaked with WD 40 and used a plastic scraper. The metal ones can damage the surface if not careful. For the finishing clean up those industrial fine scotch brites work good, 400 wet & dry sandpaper or 0000 steel wool. Also lots of patience.
19 May 2008 09:59 #214546 by violentvintagecycles
Replied by violentvintagecycles on topic Any of you long time mechanics....
Are you using the razors straight up? Use a scraper they use for removing inspection stickers, think it may be all about the leverage.
19 May 2008 12:18 #214581 by coppertales
I have tried putting LPS2, a penetrant, and mineral spirits on the gasket. They work ok when all that is left is the gasket sealer Kawasaki used to glue the gasket down. The scraper is a long handled razor blade holder so I can reach the middle of the case around the studs. It works great when the gaskets are not hard or to remove silicone sealant. Less chance of nicking the block metal too. Good thing I picked up a 100 pack of razor blades from Harbor Freight, one is just down the street, because I am using alot of them. The paint remover might help too. chris3
1982 KZ1100 A2
1982 1100 SPECTRE
1982 1100 SPECTRE
19 May 2008 19:14 #214631 by PLUMMEN
Replied by PLUMMEN on topic Any of you long time mechanics....
acetone or oven cleaner;)
19 May 2008 22:06 #214663 by bountyhunter
Replied by bountyhunter on topic Any of you long time mechanics....
Brake fluid will work on some.
BTW, the base gasket was the worst part of my engine rebuild. It was sealed at the factory with a permanent adhesive, and took major force to separate. The bonding held on both surfaces, the gasket had to split in half to come apart.
Took me three hours with a straight edge blade and scraper to get it off.
19 May 2008 22:09 #214665 by bountyhunter
Be VERY careful to keep the scrapings from falling down into the crankcase. pack clean rags against the edge you are working and stop to vacuum the edge about every couple of inches done. You really don't want that crap in the oil.
19 May 2008 22:24 #214666 by nads.com
Replied by nads.com on topic Any of you long time mechanics....
wire wheel on a dremel gets that stuff off fastr. And it all comes off too.
