1981 KZ1000 CSR exhaust problem
- saltydog
17 May 2008 06:32 #214167
by saltydog
1981 KZ1000 CSR, 1982 KZ440 ltd, 1972 Honda ct90, 1978 KZ 650
1981 KZ1000 CSR exhaust problem was created by saltydog
My bike has a piece of sheet metal, probably from some of the interior baffeling, that is floating around inside the mufler. I can't seem to be able to remove it with needle nose pliers. My question is what happens if I drill out the three rivets that seems to be holding on the back plate of the muffler? Will it come out or is it welded also? Will I be able to get it riveted back in place?
It sometimes will partially block the exhaust and it couldn't be helping anything.
Thanks,
Robert
Thanks,
Robert
- WABBMW
- Let The Good Times Roll !
- Thank you received: 16
25 May 2008 23:10 #215857
by WABBMW
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
1977 Honda Supersport 750 four (sold)
1984 Honda Nighthawk 650 (sold)
Replied by WABBMW on topic 1981 KZ1000 CSR exhaust problem
Saltydog:
I had a terrible rattle in both my exhaust megaphones. I developed a case of the "screaming mimis" after a while. It got to me so badly that I tore into it by heating the rear edge of the megaphone and bent the edge outward. Then had to heat and cut the 3 spot welds loose. After that, the entire baffel can be removed. Mine was coming apart somewhat but I welded it back together and re-installed it, then bent the edge back into position and spot welded the 3 places.
The side I worked on is now functional but looks like a dogs rear end. I haven't done the other side yet. I will either replace the entire system with an upgrade, or smoothly grind off the last 1/2" or so of the megaphone so it will have a smooth edge again and build or buy a custom baffel that won't rattle.
You could definitely get your piece of metal out by doing this, but it ruins the appearance of the rear of the unit. :S
I used to race J/24 sailboats. I suppose you have a story behind your user name.
:laugh:
:laugh:
Bill Baker
Houston, Texas
1982 KZ650 CSR
2008 Yamaha FZ1
2006 Yamaha FZ1
- saltydog
26 May 2008 06:51 #215906
by saltydog
Replied by saltydog on topic 1981 KZ1000 CSR exhaust problem
Bill,
Thanks for the reply. I'd hate to mess up my muffler any more than necessary. I think I'll check with a friend and see if maybe I can cut out the end with a plasma cutter. I'm gonna have to do something.
I live in North Texas on Lake Texoma and do some sailboat racing but my user name comes from my favorite, after beer, adult beverage.
Thanks,
Robert
Thanks,
Robert
- fweep
- 2001 ZRX1200R, 1991 KZ1000P, 1984 V45 Honda magna
05 Jun 2008 11:24 #218121
by fweep
Replied by fweep on topic 1981 KZ1000 CSR exhaust problem
If I remember correctly from The KZ1000P site , people have basically cut out a square hole from the back side or bottom of the muffler, removed the loose material and them welded the piece cut out or a patch back on the muffler and went on their way.
Maybe you could try that.
