Where is my Oil Filter
- triggerbilly
16 May 2008 20:01 #214117
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Where is my Oil Filter was created by triggerbilly
I have a kz750-E 1982
I'm waiting for my manual to arrive, I bought a new oil filter today and just had a quick look at the bike and can't find where the oil filter should go
I'm pressuming it's one of the 2 bolts right underneath the bike ???????? Am I right ????????
1982 kz750-e3
1983 cb1000c
plano. TX
- RonKZ650
- Thank you received: 240
16 May 2008 20:13 #214122
by RonKZ650
Replied by RonKZ650 on topic Where is my Oil Filter
Yes, you have 2 17mm head bolts, one all alone further farward is the drain plug, one further towards the rear of the engine that is securing a round cover is the filter.
- Bluemeanie
- Thank you received: 14
16 May 2008 20:40 #214131
by Bluemeanie
Replied by Bluemeanie on topic Where is my Oil Filter
Remove the drain plug first and then remove the filter cover, keep the pan there as more oil will still come out. Messy, messy...
- triggerbilly
16 May 2008 20:48 #214133
by triggerbilly
1982 kz750-e3
1983 cb1000c
plano. TX
Replied by triggerbilly on topic Where is my Oil Filter
YEY ALL DONE
Your're right very very messy messy !!!
Thanks a lot
(I'll be back !!!)
Thanks a lot
(I'll be back !!!)
1982 kz750-e3
1983 cb1000c
plano. TX
- RonKZ650
16 May 2008 21:42 #214140
by RonKZ650
Not that it matters, but you can drain the filter first or second. If you take the filter off first, it's oil will drain, and all remaining oil will stay in the pan, and conversely when you drain the pan any oil in the filter will still be there. Two entirely different drains. I always drain the pan first, but it really makes no difference.
