Another dumb question?
  • badrhino
  • badrhino's Avatar Topic Author
16 May 2008 08:31
#213996
Hey, is there supposed to be something other than rubber boots over the two ports on top of the valve covers towards the front of the engine. I did not know if there were to be breathers there also or vacuum lines, etc.
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • axisfx80
  • axisfx80's Avatar
Re: Another dumb question?
16 May 2008 08:33
#213998
Thats part of the egr system, there are supposed to be hoses going to them providing vaccuum from a carb port but since it's a older bike, they most likely don't work any longer so get an apropriate size hose and link both sides together with one hose. and find the carb vaccuum port and seal it since it might be open now
  • badrhino
16 May 2008 09:09
#214009
thanks, once again thats what I thought but wanted to make sure.
Franken Z!
