- Thank you received: 1
How to remove broken stud that has broken bit inside?
- squints
You should be able to drill that bit out just the same.. if needed use a punch and make a indent in the dead center of the exposed stuck bolt. Drill into bolt with a small drill bit. After hole is made, get an appropriately sized easy-out and a hand chuck from the hardware store. Tap the easy-out into hole(may have to use a rubber/wood mallet to get it in far enough) and turn by hand with chuck. Start with drilling a small hole into the bolt, you can always increase that size BUT BEWARE TO NOT DRILL OUT THE THREADS ON THE ENGINE HEAD!.
If all esle fails, you can completely drill out the bolt and threads on the head with a slightly larger drill bit than the stuck bolt. And using the same handchuck and a theading tool, rethread the drilled out hole.
have fun.
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
- squints
Upstate NY
- saxjonz
- KawboyZ
- Thank you received: 76
I will have to try that. I just put on a new pipe today and it seems to work fine for now but I want it right so I will try this first and then if that doesn't work I will try squints method. I just went today to a machine shop and they told me I didn't have to take the head off of the bike but that I could bring in the whole engine so I figured if those ideas you gave work would save me a lot of hassle and extra work. Have to find out where to get alum powder around here now. I will call around to pool places tomollow.Use clay (modeling clay, play dough, etc) and build a pocket shaped dam around the hole, then mix up some alum and water into a thick slurry (thin enough to pour). Pour the alum slurry into the pocket you built up around the hole until the hole is filled. Let it sit overnight and see if there is anything left of the drill bit or the bolt. May have to do it twice to dissolve all the bolt.
Alum should be available where swimming pool supplies are sold.
Sounds crazy, don't it? It works and won't damage aluminum.
Thanks
79 LTD B3
- enormiss
It will however erode the aluminum some.
A centerpunch and drill will eventually get it out, buy a reverse drill bit and it may eventually spin out while drilling.
I like the sound of that alum, can't hurt to try.
81 750 LTD
96 DR 350
94 DR 350
S. Jersey
- ronjones
- Thank you received: 4
- galaxian
1977 KZ1000A1, 1979 KZ650 C3
