1980 kz750 stalls and metal tinging noise
- chopkz750
15 May 2008 06:41 #213760
by chopkz750
1980 kz750 stalls and metal tinging noise was created by chopkz750
I just got a kz750 Now it has to have the choke on the whole way for like 2mins but still cant turn it down all the way. Lately i try to start it and it will start but then stalls right away the rpm barley goes above the one then comes down and stalls. And theres a metal tinging like a piece is getting tossed around on the left side. And it back fires a tiny tiny bit any suggestions? this is my first bike so not to keen on it.
- OKC_Kent
- Thank you received: 20
15 May 2008 06:47 #213762
by OKC_Kent
Oklahoma City, OK
78 KZ650 B2 82,000+ miles
Replied by OKC_Kent on topic 1980 kz750 stalls and metal tinging noise
The engine isn't idling because it sounds like the carb idle circuits are plugged up. And the metal noise may be related; the primary chains make noise when the idle is too low.
Clean the carbs and set the idle per your manual.
Oklahoma City, OK
- chopkz750
15 May 2008 10:25 #213799
by chopkz750
Replied by chopkz750 on topic 1980 kz750 stalls and metal tinging noise
Whats the best way to clean carbs never did anything to a bike before.
- OKC_Kent
15 May 2008 10:30 #213800
by OKC_Kent
Oklahoma City, OK
By taking them completely apart, soaking only the metal parts in carb dip, and blowing all passages with compressed air.
Get a manual first, you can find them on ebay. For good carb parts diagrams go to www.buykawasaki.com and search "Owners Info"
Oklahoma City, OK
- chopkz750
17 May 2008 10:33 #214184
by chopkz750
It looks like it is leaking gas out of the carb. And seems to be backfiring out of the carb it will ting and them puff out smoke. And it wont idle higher them 1rpm and then cuts out.
