Starting my '80 650 project, Questions on cylinder head.
- Tyler
14 May 2008 16:19
I have an '80 650 ltd that I need a head for, the old one is cracked. What model years will work on this engine or are they pretty much the same from 77-82?
I have the means to do a valve job but I need valve seals, where these available from? Also gonna need shims, can they be used form generic under-bucket shim kits or do I need specific kit for this motor?
Anyone with any 650 parts send me a PM.
I need of coarse the head (preferrably with valves, springs, and cams) also: a wiring harness, headlight parts, and some other small things.
As always, thanks all
"74 Yamaha DT 400 Enduro
- kawsakiman
Re: Starting my '80 650 project, Questions on cylinder head.
14 May 2008 16:37
pm sent
