what is the difference between a exhaust and intake cam
- School Teacher
13 May 2008 10:55
other than the gear for the speedo are they interchangeable?
can you run an exhaust cam on the intake side?
this is for the early kz900/1000
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- Skyman
- 1978 KZ1000-B2 LTD 1982 KZ1000-M2 CSR
Re: what is the difference between a exhaust and intake cam
13 May 2008 15:38
I think they are interchangeable. You just need to use a different set of bolt holes on the cam gear for intake/exhaust. In other words, there is one set of holes for the intake, and another set for the exhaust. There should be a stamp above the holes that tells you which is which.
At least that's how it is on the 1000 J engine cams. I can't remember what the 77-80 cams look like.
West Linn, OR
- School Teacher
14 May 2008 08:40
anyone know for sure if it is the same on early kz?
1980 kz1000G1
1980 kz1000G1
- bountyhunter
14 May 2008 10:56
School Teacher wrote:
Best way to be sure is go to either Bike bandit or babbittsonline.com and use their OEM explosion drawings that will give the Kawi part numbers. If they are the same number, they are the same cams.anyone know for sure if it is the same on early kz?
- Skyman
14 May 2008 11:17
bountyhunter wrote:
Well, I can tell you with confidence that they are not going to have the same part number. The exhaust cam has the tach drive gear. That doesn't mean that the lobes are not the same size and relative position.
School Teacher wrote:Best way to be sure is go to either Bike bandit or babbittsonline.com and use their OEM explosion drawings that will give the Kawi part numbers. If they are the same number, they are the same cams.anyone know for sure if it is the same on early kz?
West Linn, OR
- PLUMMEN
14 May 2008 11:47
ones an inny and ones an outy!:laugh: other than tach drive cams get swapped around for differant purposes all the time depending on whats laying around.
- School Teacher
14 May 2008 23:11
thanks
1980 kz1000G1
1980 kz1000G1
- FastKaw1
15 May 2008 05:57
Z1+KZ Intake and exhaust all the same. except for tack drive...
When you change to the J model you have to change the sprocket on the cam.
You can order cam's any way you like, the last set I ordered I got both ex cam's
that way I could switch cam duration+lift around. also if you have the cam's out
you may wont to slot the sprockets. For cam timing
XENU
XENU
- modprod
15 May 2008 16:29 - 15 May 2008 17:29
Last edit: 15 May 2008 17:29 by modprod. Reason: Delete
