Rear Of Engine Case...What is it?
  • badrhino
  • badrhino's Avatar Topic Author
12 May 2008 22:09
#213224
Ok, guys it has been a while since I have messed with an old bike. When I bought my KZ1000 there were a few things missing in action.
What is the round area extruding from the rear of the engine behind the crank case?
There is a inlet or outlet area for a hose that must have ran to the air cleaner inwich is also MIA.
If I run single style foam air filters how would I incoroporate this?
1980 KZ1000 with a 1982 KZ1000J motor with 1100 pistons and heads, Vance & Hines, 29MM Smooth Bores, Work in Progress
Franken Z!
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
Re: Rear Of Engine Case...What is it?
12 May 2008 22:28
#213230
You've got a couple choices anyway.
I just installed a K&N filter on my air breather,but I've heard of others just routing a hose,and hanging it out over the rear,at the swingarm frame axle-point.
I think Jeff sells those filters @ Z1,but not positive.
I've also heard that hanging it out the back could allow grits and grimes to enter the hose,but I don't know that that would be an issue or not.;)
1977 KZ1000 A-1
  • Sandy
  • Sandy's Avatar
  • Fly High,Tony
12 May 2008 22:31
#213231
Here...take a look at this(just found it)...
Air Filter
1977 KZ1000 A-1
  • badrhino
13 May 2008 06:58
#213271
Thanks Sandy,
I figured it was the crank case breather hole, but wasn't for sure. Thanks for the help!
Franken Z!
13 May 2008 10:17 - 16 May 2008 10:52
#213317
This works for me. :)
Larger clear hose is from crankcase oil breather.
Smaller clear hose is from drain hole at bottom of air box.
[click on image to enlarge -- and for legible text]
Last edit: 16 May 2008 10:52 by Patton.
  • badrhino
16 May 2008 09:07
#214008
I picked me up a little breather from Advanced Auto Parts for $9. It is red with a chrome top and bottom, fits right on there.
Franken Z!
