Sudden loss of power KZ1000Police 1980
  • Bullitt03737
  • Topic Author
12 May 2008 09:14 #213048 by Bullitt03737
Sudden loss of power KZ1000Police 1980 was created by Bullitt03737
The bike is all stock. Carbs were professionally done. I know those are correct. But I can start it fine and ride it for about 25 minutes, then all the sudden its like hitting a wall. It can barely carry its own weight. I figured out it has one bad coil. Now my question is could this coil be fine while cold, but after riding the engine heats it up cuasing it to short out or what not? Or is there something bigger going on here?
Thank you
Ian
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
12 May 2008 11:49 #213074 by bountyhunter
Replied by bountyhunter on topic Sudden loss of power KZ1000Police 1980
Bad coils typically do get flaky after they heat up. That's exactly what my coil did when it was going bad.
  • Bullitt03737
  • Topic Author
12 May 2008 11:51 #213076 by Bullitt03737
Replied by Bullitt03737 on topic Sudden loss of power KZ1000Police 1980
well. if thats the case I guess I need another set of dynas....
  • Bullitt03737
  • Topic Author
30 May 2009 19:06 #295146 by Bullitt03737
Im going to go ahead and dig this back up.
Still having the same problem. Its been parked for months and it fired right back up suprisingly. But It still has the same old problem. The 2/3 coil just stops working all together once it warms up I guess. I know for a fact the coil stops working.
The thing I have been wondering for a while now is there anything else that would effect just one of the coils once it got hot too? I would hate to think that a brand new dyna coil went bad that quickly. Im just trying to elimnate other sources of the problem before I guy another coil
30 May 2009 19:39 #295154 by 650ed
Replied by 650ed on topic Sudden loss of power KZ1000Police 1980
Here's an easy test. Swap coils. If the problem then moves to the 1&4 cylinders it MUST be the coil because that's the only thing that moved. Ed
30 May 2009 19:43 #295157 by MFolks
Replied by MFolks on topic Sudden loss of power KZ1000Police 1980
I'd do this: remove the tank, take a hair dryer and run it over the coils on high to simulate the hot working conditions the coils live in and then check with a multimeter set on ohms and see how they test.
If the resistance varies or shows less than 3 ohms I'd be suspicious of the coil(s). Check the secondary side too(I'm not sure what the reading will be).
  • Bullitt03737
  • Topic Author
31 May 2009 07:50 #295275 by Bullitt03737
That sounds like an awful lot of work to swap them coils, but It has to be done.
Im going to guess that everything else involved in the ignition is tied to both coils?
31 May 2009 08:10 #295278 by Russ Jackson
Replied by Russ Jackson on topic Sudden loss of power KZ1000Police 1980
I would swap the coils also. Then I would check the plugs and make sure the gap is correct and not fouled....Russ
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
  • Bullitt03737
  • Topic Author
31 May 2009 09:24 #295288 by Bullitt03737
It will run perfectly fine for the first 15-20 minutes. And its not an intermitant failure, its all the sudden and stays that away until it cools back down.
31 May 2009 09:54 #295291 by Patton
Replied by Patton on topic Sudden loss of power KZ1000Police 1980
Bullitt03737 wrote:
...The 2/3 coil just stops working all together once it warms up I guess. I know for a fact the coil stops working....
Have the coil windings been ohm checked while the coil is still warm?
Good Luck! :)
31 May 2009 10:04 #295292 by Patton
What ignition is fitted? Oem Kaw electronic, or Dyna-S, or ???
Just wild guessing, but thinking possibility of heat-related faiure in igniter, or right-hand-side oem pick-up coil or Dyna-S module.
Good Luck! :)
31 May 2009 10:08 #295294 by Patton
Could also be a heat-related spark plug failure on either inside plug. Have new NGKB8ES plugs been installed in inside cylinders?
Good Luck! :)
