Sudden loss of power KZ1000Police 1980
- Bullitt03737
Thank you
Ian
1980 CSR 1000. New dyna Coils, Vacumn Less Petcock, Various Handle bars depending on the day, (Drag and Clubman.)
- bountyhunter
- Thank you received: 337
- Bullitt03737
- Bullitt03737
Still having the same problem. Its been parked for months and it fired right back up suprisingly. But It still has the same old problem. The 2/3 coil just stops working all together once it warms up I guess. I know for a fact the coil stops working.
The thing I have been wondering for a while now is there anything else that would effect just one of the coils once it got hot too? I would hate to think that a brand new dyna coil went bad that quickly. Im just trying to elimnate other sources of the problem before I guy another coil
- Thank you received: 2829
- MFolks
- Thank you received: 540
If the resistance varies or shows less than 3 ohms I'd be suspicious of the coil(s). Check the secondary side too(I'm not sure what the reading will be).
- Bullitt03737
Im going to guess that everything else involved in the ignition is tied to both coils?
- Russ Jackson
- Thank you received: 1
1976 KZ 900 B1 29 smoothbores, Kerker, Lester Mags
2008 Kawasaki Concours 14 abs
- Bullitt03737
- Thank you received: 2098
...The 2/3 coil just stops working all together once it warms up I guess. I know for a fact the coil stops working....
Have the coil windings been ohm checked while the coil is still warm?
Good Luck!
Just wild guessing, but thinking possibility of heat-related faiure in igniter, or right-hand-side oem pick-up coil or Dyna-S module.
Good Luck!
Good Luck!
