- Thank you received: 104
MOTOR LOSES POWER AT 8K all fresh WHY??
- PLUMMEN
15 May 2008 08:36 #213780
by PLUMMEN
Replied by PLUMMEN on topic MOTOR LOSES POWER AT 8K all fresh WHY??
wow,im suprised you didnt fold over a bunch of valves at 10,000rpms if the cam timing changed!:S
- 9sec1000
19 May 2008 15:05 #214605
by 9sec1000
Replied by 9sec1000 on topic MOTOR LOSES POWER AT 8K all fresh WHY??
New update, Went to the track same problem by the 3rd pass.
Ran a leak down and it did great so def. no bent valves. I've seen these things run real outa whack with the centerline and still not bend valves but I am truly surprised it din't bend any especially with that kinda motor speed.
As soon as I pulled the valve cover I found the problem, bound up exhaust cam bearing. I replaced all and everything seems good now. Try this again on wednesday!
