Titanium valves, Turbo oiling, Need valves Z1
- jeff35m_73068
11 May 2008 18:37 #212913
by jeff35m_73068
Titanium valves, Turbo oiling, Need valves Z1 was created by jeff35m_73068
Has anyone resized the 7mm valves that are available cheap on ebay? what about the tip? Does anyone have extra stock straight mkII valves?.
Is there a way to modify the oiling system. to feed the turbo?
KZ's Rule!
Jeff
KZ's Rule!
Jeff
- jeff35m_73068
11 May 2008 18:45 #212915
by jeff35m_73068
Replied by jeff35m_73068 on topic Titanium valves, Turbo oiling, Need valves Z1
Will J model valves work? I know 75- exhaust valve are longer. What else will fit mkII 1000 head?
How do you add bikes to your profile????
- PLUMMEN
- Thank you received: 104
11 May 2008 20:00 #212951
by PLUMMEN
Replied by PLUMMEN on topic Titanium valves, Turbo oiling, Need valves Z1
blueprint or tighten up the clearances on your oil pump to boost pressure before feeding a turbo,or you could add a sump to pan with seperate electric pump to feed turbo;)
- APE Jay
- Banned
- Thank you received: 58
11 May 2008 22:50 #212978
by APE Jay
Replied by APE Jay on topic Titanium valves, Turbo oiling, Need valves Z1
Use KZ1000 valves with 1000 keepers.
- jeff35m_73068
12 May 2008 06:15 #213008
by jeff35m_73068
ty i didnt relize thr keepers were different too. I need to do some sorting ty
- APE Jay
- Banned
12 May 2008 14:13 #213091
by APE Jay
jeff35m_73068 wrote:
That is the only difference.
Jay
Jay
