Oil drain plug dimension
- Marp68
11 May 2008 11:48
Hi
ANyone knows the oil drain plug dimension?
Need to buy a gasket for it, and I don't want to unscrew it and let the oil out.
Cheers
M
Cheers
M
- fixer5000
Re: Oil drain plug dimension
11 May 2008 12:42
it would be most helpful to know what bike youd want this for???
1978 kz650b pretty much stock
massachusetts
massachusetts
- Marp68
11 May 2008 23:51
Sorry, thought it showed under the profile image....
It's a kz650 B2 -78.
/M
/M
- Bluemeanie
12 May 2008 05:37
Don't know the size but if it's not leaking bad just go ahead and run it till your next oil change. Then take it off and find a gasket for it. I believe factory gasket was metal.
- OnkelB
12 May 2008 06:04
The drain plug bolt is very close to 12 mm (more like 11.75 mm), the diameter of the bolt head is 20 mm. A 12 mm (inner diameter) bronze or copper washer should do the trick.
77 KZ 650 B1, 82 GPz 1100 B2.
- Marp68
12 May 2008 06:45
Perfect! Thanks!
I have recently changed the oil, but didn't change the gasket. Now I think that it would be better to have used a gasket, instead of tighten the bolt a bit hard. So I thought of retighten the bolt a bit softer this time, but with a coppar och bronze gasket to seal it.
/M
/M
