What kz1000 years are the engines the same? need a complete head assembly
- kirmit77
- FastKaw1
73-76+7? all the same
76-7 -79 the same only with pollution ports
80 and on will not inter change with out changing other parts.
I think I have the years right. IM sure someone will let you know
XENU
- Jeff.Saunders
77 & 78 heads are vry similar to the Z1 / KZ900 heads - essentially just the studs are different.
In the USA the 79 & 80 heads have emission ports. The 1980 EFI model head has other differences due to different bolt spacing on the intake manifolds and the injector ports in the head. For the rest of the world the 79 & 80 heads are the same as the 77 & 78 heads.
1981 and up are different and have a different cam chain arrangement
www.z1enterprises.com
Z1 Ent on Facebook,
- kirmit77
- wootentheone
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
81 Scratch built GPz1150R
82 KZ1000
- otakar
74 Z1-A stock
77 KZ-1000A stock
79 KZ-1300 (1400)
80 KZ-1300
82 KZ1000
- wootentheone
- Mcdroid
- Gone Kwackers
- Thank you received: 317
and if you know were i could get a 79/80 engine repair manual that would also help
Look at this eBay link tinyurl.com/2eghev2
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- APE Jay
- Banned
- Thank you received: 58
- larrycavan
- Visitor
79 & 80 are both MKII engines.
Not all of them are MKII.
Early 79 LTD1000 had the old small pin crank motors and 122 pin cam chains. The factory was trying to use up the old parts.
However, the heads are the same. Both pollution port heads.
- Cigarette38
Is there any other tell tail that defines the differance between MKII and small pin motor?
When in doubt upshift
88-95updated GSXR750R
92-06updated GSXR7/12
72' Kawi H2 x2 both blue
79 KZ1000
89 CBR600
02 YZ250
