KZ550 oil light on .
  • mjg15
  • mjg15's Avatar Topic Author
08 May 2008 16:07
#212116
I have a KZ550 w/10,000 mis. that has been sitting . I put some Seafoam in the oil and gas . The cam chain was rattling so I figured that this might loosen the tens. wedges . After idling for about 10 min it did quiet down the noise . A few minutes after that the oil light started to come on if the revs were under about 1800 . I put about 6oz in the oil . Is it possible that the viscosity was thinned enough to cause this . I will start it again tomorrow and see if it lights up with cold/thick oil . Any thoughts or experience with this ???
Thanks
'80 Z750fx
'81 KZ550A
'81 GPz550's, Too many!
'82 KZ1000R
'82 GPz750
'90 ZR550
Project photo album: s163.photobucket.com/albums/t289/mg15_ph...GPz-ZR550%20project/
s163.photobucket.com/albums/t289/mg15_ph...current=DSC01286.jpg
  • Mark Wing
  • Mark Wing's Avatar
Re: KZ550 oil light on .
08 May 2008 16:59
#212136
My guess is the oil has been thinned. I would change the oil and filter then try it again.
Yorba Linda Cal.
  • Werewolfx
  • Werewolfx's Avatar
08 May 2008 18:45
#212161
My oil light would come on when it was up to full operating temp at low rpm any time my oil was getting to be due for changing..I concur, change the oil and filter and see what happens..
Chris
  • mjg15
08 May 2008 19:00
#212166
That's what I'm hoping . I'll post back after I try it cold and with some fresh oil .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • oldcoldankles
  • oldcoldankles's Avatar
08 May 2008 21:05
#212196
The Seafoam may have caused the oil to foam up resulting in loss of oil circulation. A few years ago one of the members fried his KZ750 Spectre engine trying to ride into the mountains with too much Seafoam in the oil.
Peachland BC
1981 KZ1000 CSR M1
1983 KZ550 LTD M1 (Shaft)
1989 Corvette coupe
  • mjg15
08 May 2008 22:44
#212218
It looked normal thru the sight glass , but maybe you can't tell from that .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
  • BSKZ650
  • BSKZ650's Avatar
09 May 2008 05:19
#212262
I am not a fan of putting addatives in the oil that are supposed to "clean" the engine.
If and when whatever you add to the oil breaks the sludge or what ever is in there down, it has only one place to go, the oil pump pick-up screen, it can and will clog the screen and cause engine damage
77 ltd1000, current rider
76 kz900, just waiting
  • bountyhunter
  • bountyhunter's Avatar
09 May 2008 12:33
#212359
Good point. If you do a throgough cleaning at every change, it's probably OK. But if you only do it when it's loaded up, that could loosen a buch of sludge.
  • mjg15
09 May 2008 13:02
#212366
I got to run it in the garage for a while this afternoon . I let it run for about 10-15 min and the light didn't come back on . I'm going to do an oil change before I run it again. The cam chain is nice and quiet now .
'80 Z750fx
'81 KZ550A
'82 KZ1000R
'82 GPz750
'90 ZR550
