Do you have to split the cases to change the crankshaft oil seals on an 81 Kz750. the one under the ignition side has a very small leak. Someone mentioned I could cut the lip off of the seal to get in in there, but I would rather do it correctly.
1979 kz650 B. Chicago, Illinois
