- Thank you received: 1
Welded Balanced Crankshaft
- badboie
05 May 2008 20:39 #211483
by badboie
Welded Balanced Crankshaft was created by badboie
ok so whats the benifit to this?? I would like to know. I saw it mentioned in a post.
- wiredgeorge
05 May 2008 20:59 #211488
by wiredgeorge
Replied by wiredgeorge on topic Welded Balanced Crankshaft
Cranks are welded because when you do a jack-rabbit start, they tend to twist and the welds give them torsional strength. Once you have added weight, it is prudent to rebalance.
- PLUMMEN
- Thank you received: 104
05 May 2008 22:31 #211496
by PLUMMEN
Replied by PLUMMEN on topic Welded Balanced Crankshaft
its a cheap insurance policy if you like to ride hard or launch on a regular basis with a sticky rear tire.trueness of the crank is more of a priority than balancing the crank.as long as the pistons are close it tends to cancel itself out,the little bit of material from welding is neglegible(spell check)since it is towards center of crank
- themachine
- Thank you received: 4
06 May 2008 12:33 #211591
by themachine
82 kawaski csr1000 Evolved into a streetfighter.
I love Speed! Hot Nasty Badass Speed!!!
Replied by themachine on topic Welded Balanced Crankshaft
so after a hard launch you'r engines pistons won't meet the valves.
- PLUMMEN
06 May 2008 12:52 #211596
by PLUMMEN
themachine wrote:
banging valves is mostly caused by missed shifts/over revving or bad valve springs not by twisted crankshaftso after a hard launch you'r engines pistons won't meet the valves.
