Shifter shaft leak
  • ran429
  • ran429's Avatar Topic Author
  • Master of FREE rides!
Shifter shaft leak
05 May 2008 17:45
#211432
On my police bike, the shifter shaft is dripping a little bit of oil, are these seals very easy to replace?
  • OKC_Kent
  • OKC_Kent's Avatar
Re: Shifter shaft leak
05 May 2008 18:20
#211441
It is if it's anything like my 750 Shaft drive. It's not too expensive at the dealer.
On my bike I just had to remove the outer case cover, remove the seal and slide the new one on the shift shaft and into the case. My package said to wrap a little masking tape over the shaft splines to keep them from tearing the seal as you slide it on.
Cashion, OK
78 KZ650 B2 85,000+ miles
  • ran429
05 May 2008 20:57
#211487
ok, cool. thanks!
I will go get one soon and attack that drip my boss pointed out today.
