- Thank you received: 1
cylinder not firing
- squints
Its been like this for i dont know how long, i only noticed because I swapped in a 4-1 and that cylinders pipe wasnt blueing. :dry:
SOOO, I was wondering if it running on only 3 of the 4 cylinders for who knows how long would cause any damage?? or other problems down the road? Is it ok to ride as is for now or should I not until its fixed??
traded my classic Kz's for a 2001 Kz1200r
Upstate NY
- vach
1979 kz650 B. Chicago, Illinois
- squints
ill sort it out eventually, but really my question is it ok to ride for now here and there or should I avoid riding all together until all cylinders function properly.
Upstate NY
- vach
- BSKZ650
- Thank you received: 14
you say you are getting fire to the plug, is the plug wet with fuel?, if not then I would think a carb issue may be causing the problem,, but there needs to be a bit more work done to determine what the real issue is
77 ltd1000, current rider
76 kz900, just waiting
- Qdude
- It is all good.
77 KZ 650 C1.
77 KZ 650 C1.
- squints
kz1`000
Upstate NY
- squints
Upstate NY
- Thank you received: 2098
But is it ok to ride as is in the mean time if requires a little carb fiddleing?? kz1`000
It's too soon to fiddle with the carbs, and would just complicate the diagnosis at this point where ignition and compression are pre-requisite determinations.
#4 plug is most likely fuel-fouled beyond recovery. It might look okay, even newish, and perhaps even spark under no compression -- but it is most likely doornail dead.
Would first install brand new sparkplug in #4.
Next, swap #1 and #4 plug wires -- put #1 wire on #4 plug and #4 wire on #1 plug.
Test run engine to see if non-fire moves from #4 to #1. The non-fire will either continue on #4 or move to #1.
Use water spray bottle to mist exhaust header pipes while engine is running. Do not touch any of the pipes. Hot pipe from firing cylinder will vaporize the water spray with immediate sizzle. Non-firing cylinder allows water mist to just run down the pipe.
Post test results so we'll know how to best proceed.
Good Luck!
- modz1r
NGKs seem very prone to fouling/dying these days.
- squints
And to clarify further (that I'm givng rightinfo), while sitting on bike, cylinders are (L-R)1-2-4-3...
Upstate NY
ok patton, before i rip everything apart, youre sayin to swap the #1 and #4 ignition cables and plugs. To do this I would 1)simply unscrew cable from ign.coils and swap cables Or 2)are you saying to simply reroute the cable to the different cylinder leaving the connections at the ig coil the same.
Don't remove the plugs -- just leave them in.
The plug wires from the coil to #1 and #4 plug are usually long enough to allow swapping them for each other. But if the wires aren't long enough, let us know.
The results of this test will provide some diagnostic clues regarding the ignition.
Good Luck!
