1976 to !979 Engine Part Compatibility
- jplata
01 May 2008 09:01
I have a 1979 Kz750 twin that needs lots of new parts for the engine, as of now i think i need a dynamo and starter clutch for sure. I found a '76 KZ750 twin motor on Craigslist for 85 bucks. Does anyone know if i can use parts from this '76 to fix my '79
- steell
Re: 1976 to !979 Engine Part Compatibility
01 May 2008 11:36 - 01 May 2008 11:39
Everything but the alternator (dynamo) and left side engine cover will interchange. 76-77 have an alternator that is energized and controlled by a coil (and separate regulator and rectifier), 78-80 and 82-83 (84 in Canada) alternators are permanent magnet and interchange.
I'm sure I have an alternator around here somewhere, probably not a good starter clutch though. Starter clutches are rebuildable, I think Jeff at Z1 Enterprises can get the parts.
Where are you located?
Last edit: 01 May 2008 11:39 by steell.
- jplata
01 May 2008 12:22
I am located in Dallas. I have had a hard time finding parts. I am about to relocate to Colorado in a few weeks so getting the bike running is a big task before i leave.
- steell
01 May 2008 13:58
Figure out what parts you need, then PM me and I'll take a look and see if I have them.
I have a lot of engine parts left, not so much in the way of other parts.
- 76 LTD
01 May 2008 15:28
I am junking a 76 still has some good engine parts left.
