kz750e2 modified
- mls81kz750e
kz750e2 modified
29 Apr 2008 12:52 - 29 Apr 2008 12:54
This is my kz I recently go up and going. It has a sportster style rear fender, changed headlight, shortened rear shocks, and the exhaust was cut off at the bottom of the motor. All of this was done when I got it, I had to clean the carbs and doing a bit of wiring (or cleaning up wiring rather) and she is up and going. It is a very very comfortable ride, just extremely loud. and the #1 carb overflow tube is cracked so I think I need a new bowl for #1. The engine however runs very very nice, I just don't want to cause any problems by running it with the exhaust like this.
1981 kz750e: lowered rear, sportster style fender, changed headlight, no controls on bars,
Last edit: 29 Apr 2008 12:54 by mls81kz750e.
- mls81kz750e
Re: kz750e2 modified
29 Apr 2008 12:58
I would like to find a header that I could use with the kz750 I would like to know what other bikes the header will work with this bike if anyone knows that would be great
- mariozappa
29 Apr 2008 13:25
650 and 750 engines have the same size and spacing for exhaust ports.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- mls81kz750e
29 Apr 2008 15:39
what about like the ninja 750 or gpz750 or the 650 versions of the same then would they work as well??
29 Apr 2008 15:54
mls81kz750e wrote:
Here are some possible repair options for the cracked overflow tube, any one of which just might work, at least temporarily.
Shrink tubing.
Thin- wall tight-fit plastic tubing.
Solder.
JB Weld.
Good Luck!
... #1 carb overflow tube is cracked so I think I need a new bowl for #1....
Shrink tubing.
Solder.
JB Weld.
Good Luck!
- mls81kz750e
29 Apr 2008 17:24
will shrink tubing or thin wall plastic hold up with the gas though? Great ideas thoug I thought for sure I'd have to find a replacement, not now cuz I have all these available
- mls81kz750e
29 Apr 2008 18:35
I am looking for a used exhaust header if anyone may have one laying around
- steell
29 Apr 2008 19:57
mls81kz750e wrote:
650 till 82 (last year I think), 750 till 85 (including GPz750), and ZR7 (somewhere in the 98-2002 range, whatever years they were manufactured, air cooled 750 four).
If it's not an air cooled 650-750, it won't fit without modification. At least one member has bent Zx6 or Zx7 pipes to fit, but I can't remember who.
- mls81kz750e
30 Apr 2008 04:16
cool that widens my search a bit
