head flow rates
- School Teacher
head flow rates
28 Apr 2008 12:57
ok i thought i saw a link on the forum about head flow rate comparisons. i have searched the forum to no avail. anyway any one know of where i saw it? it had the kz the j and the 83-84 gpz head on there.
thanks in advance!
thanks in advance!
1976 kz900 in parts but will be going some day soon
1980 kz1000G1
1976 kz900 parts bike
1979 kz1000 shaftie parts bike
1978 kz1000 33mm smoothies 1075 kit
Troutdale Oregon USA
1980 kz1000G1
- PLUMMEN
Re: head flow rates
28 Apr 2008 13:02
i think it was one of Larry Cavanough(im sure i just butchered his last name,sorry Larry !)posts,he builds a lot of motorsB)
- saxjonz
- KawboyZ
Re: head flow rates
28 Apr 2008 15:11
www.flowbenchtech.com/porting/CRH/motors...e_Package_Prices.htm
Woomp there it is. I heard a lot about this guy. I was considering having him build my bike for me but he isn't cheap. I don't have the extra cash flow at the moment to drop 7 grand on the engine just yet. I talked to him on the phone. He knows his stuff for sure.
79 LTD B3
- saxjonz
- KawboyZ
Re: head flow rates
28 Apr 2008 15:12 - 28 Apr 2008 15:13
PLUMMEN wrote:
Larry Cavanaugh I think is how he spells it.i think it was one of Larry Cavanough(im sure i just butchered his last name,sorry Larry !)posts,he builds a lot of motorsB)
79 LTD B3
Last edit: 28 Apr 2008 15:13 by saxjonz.
- steell
Re: head flow rates
28 Apr 2008 16:15 - 28 Apr 2008 16:17
Pick on Larry Cavanaugh time
Just exactly what is a "Thrush Bearing"? Is that one that flies and sings??
Top line at www.flowbenchtech.com/porting/CRH/motors...e_Package_Prices.htm
Install Big Pin, Thrush Bearing, Index, Weld Crankshaft
Last edit: 28 Apr 2008 16:17 by steell.
- saxjonz
- KawboyZ
Re: head flow rates
28 Apr 2008 17:26 - 28 Apr 2008 17:32
So school teacher what do you teach?
Kids these days are so nutty :S
I don't know how I have done it for going on 11 years. Certainly a new challenge every day.
79 LTD B3
Last edit: 28 Apr 2008 17:32 by saxjonz.
- School Teacher
Re: head flow rates
29 Apr 2008 11:06
thanks guys
i teach 6th grade about ten yrs and the way i keep sane is i cage fight as well....true story(its me in my avatar)
1980 kz1000G1
1980 kz1000G1
- School Teacher
Re: head flow rates
29 Apr 2008 11:12
i checked this out but i thought i saw a side by side comparisons of the kz,j and gpz head. any help?
1980 kz1000G1
1980 kz1000G1
- OnkelB
Re: head flow rates
29 Apr 2008 12:29
School Teacher wrote:
Damn. :blink: Hope it´s you on top.
77 KZ 650 B1, 82 GPz 1100 B2.
- saxjonz
- KawboyZ
Re: head flow rates
29 Apr 2008 15:15 - 29 Apr 2008 15:18
It's there you have to go to home and look at the site a little. Home then to the tab that says kz data.i checked this out but i thought i saw a side by side comparisons of the kz,j and gpz head. any help?
79 LTD B3
Last edit: 29 Apr 2008 15:18 by saxjonz.
- School Teacher
Re: head flow rates
30 Apr 2008 11:27
found it thanks guys! and yes i'm in the black.
1980 kz1000G1
1980 kz1000G1
- larrycavan
Re: head flow rates
02 May 2008 03:25 - 02 May 2008 03:36
saxjonz wrote:
Guys....all motors don't cost 7 grand. Those engine package prices with all the goodies that are available. They contain the one time through, put in all the good stuff approach. They're for the guy that's after a bike he's going to keep and wants to do the motor one time and be finished as opposed to risking component failure and possible throwing away the money already spent because something let go and trashed the motor.
It's always the owners call as to what they are willing to risk vs the budget vs their expectations. I point you to the good parts and make suggestions on what you need for the project.
What you have to remember is this. Certain components are so old that they're just not practical to re-use. Cam chain idlers, rollers, etc. for the most part are whipped when the motor's are torn down. Those are no cheap to replace anymore.
What a guy might toss in a dragbike is very different than what a guy should have in a street bike. I see drag racers run cam chain rollers that I'd toss in the trash in a heartbeat. They have a different agenda though. They're running 1/4 mile at a time and the hauling truck is never far away.....
Entirely different story on the street.
Build a motor on a good foundation with good components...sure it costs money these days. On the other hand, do you want to drop a grand into a ported head and cams, then harness them to a questionable bottom end and worn out cam chain components?....
Making HP on a Kz or J motor is not that difficult when you know what the tricks are. Unfortunately serious power should be supplemented with a reliable bottom end [crank / trans / clutch].
Neither side of the engine is cheap to do [top end / bottom end].
What you spend on the bottomed end, isn't something that reall gives you that seat of the pants or time slip buzz you crave. That's all in the top end of the motor....However, there's a balance point of HP made from the top end components vs the breakage factor of the bottom end components....see that I mean?
I'm a big time stickler about details and having things "just right". With no control over the cost of the parts [and they ain't getting cheaper as time goes on] all I can do to help guys out is keep costs reasonable on the labor side of the coin. It takes time to tear down one of those motors and go through it properly, then reassemble it, degree the cams...etc.
The days of building a low cost KZ are long gone. But then again...price some cams for a ZX14, pipe & Power Commander....
Best Regards,
Larry C
Best Regards,
Larry C
Last edit: 02 May 2008 03:36 by larrycavan.
