Are all kz1000 heads the same?
  • JerseyBomber
  • JerseyBomber's Avatar Topic Author
  • BOO-YAH
27 Apr 2008 14:10
#209558
One spark plug hole was helicoiled by an epileptic gorilla. she runs, and im not spending a dime on her till i know i can get a registration, but for reference:
Will any 1000 head fit a 79?
And as a side note, are all kz1000 frames around 79 the same, shaft or chain?
Thanks,
Craig
1979 KZ1000 ST Mean, fast, and fugly.
Parting out: \'80 XS400G
PM me!
  • Jeff.Saunders
  • Jeff.Saunders's Avatar
  • Vendor
  • Vendor
Re: Are all kz1000 heads the same?
27 Apr 2008 15:46 - 27 Apr 2008 15:47
#209583
Chain versus shaft (KZ1000E) - think of it as a different animal entirely.
77-80 chain drive frames are all very similar - some differences between the variants LTD (KZ1000B ), Standard Model (KZ1000A), Police (KZ1000C), Z1R (KZ1000D) and Z1 Classic (KZ1000G) - The Z1R has the biggest differences, but the engines interchange between all of them.
The variants of the heads on the 77-80 KZ1000's. 77-78 is essentially a Z1 head with 8mm exhaust studs. The 79-80 heads in the USA have emissions ports in the heads - these require matching cam covers. The Z1 Classic head will fit, but has fuel injection ports in the intake. The injector holders have different bolt spacing to the carburetted bikes.
This email address is being protected from spambots. You need JavaScript enabled to view it.
www.z1enterprises.com
Z1 Ent on Facebook,
Last edit: 27 Apr 2008 15:47 by Jeff.Saunders.
  • Jack
  • Jack's Avatar
28 Apr 2008 06:30
#209725
Good run through Jeff. Canadian castings of 79-80 MKll's and all J or GPZ cylinder heads don't have the emissions ports. Over the years we've sold lots of Canucklehead rocker covers to folks who wanted to block the ports and lose those ugly covers.
79 KZ 1075 MKll
79 KZ 1500 MKll dragbike
Gone but not forgotten:
3 X 73 Z1's
1 X 74 Z1A
1 X 75 Z1B
  • 79MKII
  • 79MKII's Avatar
  • Love Them Kaws!
28 Apr 2008 10:34
#209797
Jeff pretty much covered it. I did some research not too long ago and found that the shaftie head has the same part number as the MKII head (79 KZ1000 A). Those units came from the factory in black. I think (not 100% sure) that the '79-'80 LTD heads are the same but not black.
The Kaw List:
  • JerseyBomber
  • BOO-YAH
28 Apr 2008 18:57
#209897
Ok, so to my understanding, any will fit from those years with no mods? I there a set i should look out for over others? Smaller chambers/higher flowing?
So if i wanted to frame swap, a shafty one it must be? or can i throw my engine into a chain driven chassis?
Really appreciate all the info
PM me!
  • z1turboman
  • z1turboman's Avatar
29 Apr 2008 16:20
#210123
I need help! I have a 74 z1 with blown motor, and can buy an 89 kz1000j for $400 but I am not sure if it will fit directly. Any sugestions? Thanks
74z1turbo issues, 75z1turbo issues, 76kz 900 4sale, 77kz900 rebuilding, 1000jELR past, GS1150ES past
  • PLUMMEN
  • PLUMMEN's Avatar
29 Apr 2008 17:09
#210132
step away from the poor z1,we will be by to pick it up!:laugh:
  • wiredgeorge
  • wiredgeorge's Avatar
30 Apr 2008 07:35
#210284
The motor mount points are different. The engine could be used if you are clever with a welder. I would stick with a 903/1015 earlier type motor.
As far as the heads, what has been said so far is pretty much true. The later smog head has a bigger idler assembly and if you use an earlier head, you can't use the later idler assembly which doesn't fit under the valve cover. In addition, the 903 valves have different split keepers and the indentations on the valves for the keepers are shaped different so you need to use the correct split keepers depending on which valves are being used.
