kz650 oil cooler?
- 77KZ650
kz650 oil cooler?
16 Oct 2005 12:17
Hi, what would be a good brand of oil cooler to install on a 77 kz650? (with lots of engine mods) Also, how/where are the lines connected to the motor? thx
07 MDP Rookie of the Year
- Snakebyte
Re: kz650 oil cooler?
16 Oct 2005 18:13
A guy on her has a 650 oil cooler on his bike and if you look really close at his pics you can see that the oil cooler is hooked up to one of the plugs on the side near the bottom under the crank.
what ever oil cooler you deside to go with make sure it is a stepped cooler. I know b+m make one. The stepped cooler makes a 10 degree difference from the regular finned one. Also its stonger.
I belevr I saw a pic of his bike in the new members, his name is John Stead.
Post edited by: Snakebyte, at: 2005/10/16 21:18
- rstnick
16 Oct 2005 20:13
There are 2 connections set up for the cooler. One is where Snakebyte mentions, right side bottom front of engine. I have a cooler on my bike. A Derale. It was installed in the '80s by a shop I had a lot of work done at the time. Mine is not connected at the factory locations though. Why I don't know. I've always wondered why they hookd it up the way they did. I do recall them saying it was not getting warm, so they set it up differently. I can try to take a good look at it and take some pics if you like.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- Mark Wing
16 Oct 2005 23:13
You can also get a oil pan and cooler off a GPZ 750. You just mave to block off where the sending unit mounts.
Mark
Mark
Yorba Linda Cal.
Yorba Linda Cal.
- 77KZ650
17 Oct 2005 21:11
rstnick, some pics of your setup would be greatly appreciated.thx
- Murphyau
Author
17 Oct 2005 22:22
I have uploaded two files into the Non Model Specific area of the Filebase that you might find or interest.
- 77KZ650
18 Oct 2005 07:21
Murphyau, thanks a lot, thats exactly what I needed.
- rivieracadman
18 Oct 2005 09:45
rstnick - I've been interested in doing this conversion myself. Could you U2U some info?
- rstnick
18 Oct 2005 14:52
Here's a pic of my 2 connections. Again, it was done by a shop in the '80s. They drilled and tapped holes for the fittings. The Red arrow shows the feed connection which is just in front and to the right side of the filter cover. There is a cast spot in the pan as if something was to go here. The yellow arrow is the return line from the cooler. It connects at the rear side of the filter.
The blue arrow is pointing at the stock? return connection.
Why the shop did this at the time I have no idea, it seems so much easier to use the two connection points listed/meant for an Oil Cooler. I do recall them saying the cooler was not warming when they hooked it up at first, but if they used those 2 points, I don't know.
Post edited by: rstnick, at: 2005/10/18 18:00
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rstnick
18 Oct 2005 15:07
Looking at the Oil Path route in the filebase, it looks like hooking the cooler to the rear right connection (blue arrow) and the other connection under the Oil Pressure switch, will bypass the filter. Is this correct? Will you also get a pumping action hooked up to these points? As it looks like the connections are to the same oil passage, just at different ends.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
- rivieracadman
19 Oct 2005 11:18
I checked out that article too and was wondering the same thing. Isn't the right front bleed off from the post filtered flow moving up the cylinder block to the cams? And I suspect that the rear inlet is the pre filtration area. Then again, I could be completely wrong. Maybe if engines were made of glass
