Cylinder 2 won't run, valve issue?
  • cuds
  • cuds's Avatar Topic Author
Re: Cylinder 2 won't run, valve issue?
27 Apr 2008 08:32
#209459
I can't get the freaking thing started now! I tried yesturday for a hour and a half, all I can get is sputtering. I fixed the clearances on cyl 4, so now all the valves are within spec. I think it's a carb issue, but I'm so burnt out on it. All I can get is sputtering, and when it starts for a second, I can feel all the fuel spit on mt leg.
Erik B
Bay Area, CA
1976 KZ900
27 Apr 2008 08:46
#209461
cuds wrote:
... maybe I got the timing off when putting it back together. Is there a way that it would start, even if I was one tooth off? ....
What was disassembled and then reassembled that would cause suspicion of the cam chain being one tooth off? :unsure:
