Engine oil
- Goatman
So, this is a rookie question but I am going to ask anyway.
Just bought an 86 kz1000p with some tinkering I have it running but before I get to serious I would like to change the oil, what viscosity do I use and is any brand better for bikes than others?
I also would like to hear your thoughts on the 1000p.
- Sandy
- Fly High,Tony
- Thank you received: 13
There's alot of different opinions on which BRAND to use...I've been using Pennzoil for the past few years or so,and am happy with it.
1977 KZ1000 A-1
- donthekawguy
- Thank you received: 8
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
- 76 LTD
- twinkyrider
78 kz1000A
Fond du Lac,WI
- Thank you received: 2829
OIL
- Goatman
- rstnick
- Thank you received: 377
Anything but synthetic. The wet clutch no likey the slippery stuff.
I'm using Kawasaki Synthetic oil on the advise of a Kawi mechanic.
It's mineral based (Dino oil) and has not caused my clutch to slip. My engine revs so much smoother, and power overall seems better. I highly recommend it!
I've been using it for just over a year.
Rob
CANADA
1978 KZ650 C2, 130K kms, Delkevic ex, EI, CVK32, PMC easy clutch, ATK fork brace, steering damper, braced swingarm, 18" Z1R front wheel.
2000 ZRX1100
2011 Ninja 250R
2005 z750s
- davenkids2001
I change my oil twice a year, Spring and mid-summer, usually.
I believe this is sufficient and cost-effective for my uses.
That's my 1% for the day.
Dave and Janet
Great Lake State
1979 650SR
- MCH650SR
I use the Rotella because it is quite inexpensive, so frequent oil changes aren't a problem.
I also use Rotella T diesel in my 79 chevy truck.
just my experience
1979 KZ650SR
modified with BS32 carbs
Yoshimura 4 in1
2006 Kawasaki Sherpa
1979 Honda CX500
BC Canada
- bountyhunter
- Thank you received: 337
New to the forum and new to kawasaki
Asking what the best oil is will generally start a debate... but, IMHO, the heat and shear stress of MC engines is best served by synthetic oil. There are some very good conventional oils also, but I've run syn since it came out. Just don't use the stuff marked "fuel mileage efficient" or such because they have some friction reducer which might make the clutch slip. Stick with Castrol Syn and you can't go wrong.
- jetubet
