engine noise
- deathcoleman
23 Apr 2008 18:47 #208579
by deathcoleman
engine noise was created by deathcoleman
i ran my kz 650 low on oil and now when i throttle up it makes a bad rapping sound, any ideas on what it could be
- steell
23 Apr 2008 19:12 #208584
by steell
Replied by steell on topic engine noise
Nothing good, that's for sure
Could be rod or main bearings, wrist pins, or piston slap, but piston slap usually changes with engine temp.
Running it with insufficient oil damages all the above, plus cam and cam bearings, transmission gears and bearings, etc. Pretty much just trashes the motor.
- Sandy
- Fly High,Tony
- Thank you received: 13
23 Apr 2008 21:18 #208625
by Sandy
1977 KZ1000 A-1
Replied by Sandy on topic engine noise
What Steell said...could be ugly.
How "Low" DID you run it,btw?...and for how long?
How much oil did you have to put back in to top it off?
1977 KZ1000 A-1
- BSKZ650
- Thank you received: 14
24 Apr 2008 04:19 #208665
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic engine noise
if you havent allready,, drain the oil and pull the filter apart,, look for metal if you see the stuff in there it is a sure sign you got trouble on the way
- deathcoleman
24 Apr 2008 13:36 #208777
by deathcoleman
Replied by deathcoleman on topic engine noise
i only ran it for like 2 miles i was on my way home. i am pretty sure the motor is shot. does anyone know where i can buy a new or rebuilt motor,and for how much
- bountyhunter
- Thank you received: 337
24 Apr 2008 13:54 #208782
by bountyhunter
Replied by bountyhunter on topic engine noise
deathcoleman wrote:
If it's a metallic sounding knock, it's a rod bearing.
- bountyhunter
24 Apr 2008 13:55 - 24 Apr 2008 13:58 #208783
by bountyhunter
deathcoleman wrote:
The dismantlers might be the first place to look.
www.50highwaycycle.com/
www.tiaromotorcyclewreckers.com/Nos%20Kawasaki.htm
www.fullthrottlecycles.com/_vti_bin/shtml.exe/index.html
Last edit: 24 Apr 2008 13:58 by bountyhunter.
