- Thank you received: 5
gpz exhaust stud size??????
- jordan
22 Apr 2008 19:38 #208330
by jordan
KZ810 streetfighter kz/gpz/gsxr
1983 gs1100e
1979 KZ 1000 1428 dragbike project
1974 kawasaki H1 500 sold
1972 Kawasaki s2 350-parted on ebay
1973 Kawasaki s2 350-parted on ebay
1982 kz750(sold)
1978 kz650 hardtail(sold)
1975 honda xl250-sold
1971 yamaha R5-sold
1982 yamaha xs400
gpz exhaust stud size?????? was created by jordan
I have completed building my engine with a 1983 gpz 750 head. I am finishing up the last few minor details. I went to the hardware store and bought 8 studs. I knew the studs on my other 750 were 6mm so thats what I bought. When I got back into the shop I soon realized that the studs were too small. The next day I went back to the hardware store and bought an 8mm stud and a 10mm stud. The 8mm stud fit perfect. Is this the way it is supposed to be or did somebody drill out the old threads and tap them for 8mm? If they are right this would mean that the exhaust would have holes big enough for 8mm studs. If somebody did drill and tap the head i would have to find some 8mm to 6mm studs, and the ones at the hardware store aren't long enough. Any help, wisdom, or suggestions?
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
- jdreadrocker
22 Apr 2008 20:14 #208337
by jdreadrocker
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
72 honda cb500, 2003 Buell Blast P3
Replied by jdreadrocker on topic gpz exhaust stud size??????
thats a good question! I am going to have to buy studs myself for an 82gpz. i'm glad you posted that because i was just about to buy some studs just assuming that they were the same size.
83'GPZ750-r1
Bald Knob, Arkansas
other bikes owned:
- Thank you received: 2098
22 Apr 2008 20:53 #208343
by Patton
Replied by Patton on topic gpz exhaust stud size??????
8mm and 6mm exhaust studs are available from Z1E.
As I recall, the threads on one end of the stud are cut slightly different (not quite standard) so as to more tightly fit when screwed into the head. So it is important to know which end is which. And probably won't find anything like this in a hardware store.
exhaust studs
Good Luck!
exhaust studs
Good Luck!
22 Apr 2008 20:58 #208345
by Patton
And be careful about any drilling or re-tapping or thread chasing inside the head, as it is easy to cut through into an oil channel on some of these bikes. In which case the oil will eventually work its way to the outside and make a mess on the fin area.
Just a reminder.
Good Luck!
Just a reminder.
Good Luck!
- jordan
23 Apr 2008 20:59 #208620
by jordan
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
Replied by jordan on topic gpz exhaust stud size??????
Thanks alot for the stud info! I was deathly afraid that after all my hard work i was gonna need a new head because someone f*$#%d up this one! Once again i am in debt to kzrider
1983 gs1100e
1982 kz750(sold)
1971 yamaha R5-sold
1982 yamaha xs400
