kz 750 twin
  • bigheadkz
  • bigheadkz's Avatar Topic Author
kz 750 twin
21 Apr 2008 09:47
#208003
Always had inline fours. So my question might be a little weird . Does the or is the kz750 twin shake like a twin.mine shakes like a vtwin runs and sounds cool just want to make sure the vibration was ok.
NAte
  • bountyhunter
  • bountyhunter's Avatar
Re: kz 750 twin
21 Apr 2008 09:50
#208004
NAte
My '79 750 twin has always had very little vibration because of the internal balancers. It really is very smooth.
  • macattak
  • macattak's Avatar
Re: kz 750 twin
21 Apr 2008 18:52 - 22 Apr 2008 10:51
#208082
It depends on what you're accustomed to. It vibrates more than a four, much more at higher revs. If you're used to twins, not so much.
Last edit: 22 Apr 2008 10:51 by macattak.
  • 76 LTD
  • 76 LTD's Avatar
Re: kz 750 twin
21 Apr 2008 19:15
#208087
If you dont like the vibration you can remove the top engine mount(a trick i learned on the old 450 Hondas)it will greatly reduce felt vibrations.
  • steell
  • steell's Avatar
Re: kz 750 twin
21 Apr 2008 20:29
#208104
My wife must be right when she says I'm an insensitive clod, because I don't notice much vibration on my 79 750 twin :D
I did notice a vibration at 4k rpm on my way home tonight, it was smooth above and below 4k, so maybe the motor mount bolts are loose. I'll check them tomorrow since I haven't checked them since I bolted the motor in. Compared to Brit bikes (especially the BSA 441 Victor, and excepting the Norton with isolastic) my 750 twin is smooth as glass.
She may be right about the insensitive part, but I still contest the clod part :D
  • Shoe48
  • Shoe48's Avatar
  • Live each day as it is your last
Re: kz 750 twin
21 Apr 2008 20:37
#208107
My twin has a lot more than any inline four I ever had But still not bad .. part of owning a twin :)
  • bigheadkz
Re: kz 750 twin
22 Apr 2008 02:18
#208140
thanks guys i tore the motor completely apart and rebuilt it . timing marks were correct on balancers. just new to it i guess.
