750 4 cyl cylinder heads
- gpzrox
21 Apr 2008 02:32
All the same? Looking at parts for my GPZ, have the cams, but want to make sure that the other stuff works. do I hear something weird about the tach drive, or am I completely off base here?
Thanks guys.
Louie
Thanks guys.
Louie
84 GPZ750. Modded with stock Kawasaki parts: ZR-7 shock, ZX-6 coils, GPZ1100 throttle, EN454 brake, GPZ900 fuse box, etc. and non stock: Ken Sears mirrors, K&N filter, Pirelli Sport Demons.
- steell
Re: 750 4 cyl cylinder heads
21 Apr 2008 05:57 - 21 Apr 2008 05:59
Differences I have confirmed.
80-81 750E/H heads have provisions for roller cam chains like 650's, rounded fins, tach drive.
83-85 GPz heads have squared fins, no provision for roller cam chains, no provision for tach drive.
Things I have read, but "not" confirmed personally.
80-81 750 E/H heads have smaller combustion chambers than later heads.
83-85 GPz heads have minor porting and the largest combustion chambers of the 80-85 750's.
I have read that there is some difference between the valves in the 83-85 GPz750's and the other 750's, they may be longer, can't recall what the difference was suppose to be at the moment.
There may be other differences, but that's all I can recall right now.
I have 80 750E, 81 750H, and 83-85 GPz, heads here, if there is anything specific you want me to check, just ask.
Last edit: 21 Apr 2008 05:59 by steell.
- vach
21 Apr 2008 10:43 - 21 Apr 2008 10:44
hey steel... is there anyway to I.D. a head. i have what is supposed to be an 80 kz750 h head. from what i remember the top of this looks like my 650 head.
1979 kz650 B. Chicago, Illinois
Last edit: 21 Apr 2008 10:44 by vach.
- mariozappa
21 Apr 2008 11:06
Ummmm....
That's a set of cylinders (jugs) not a head.
1977 KZ650C1
and the KZ650/KZ750 Conversion
- vach
21 Apr 2008 11:12
ok, my mistake.... is there any way to tell if these cylinder jugs are from an 80 kz750h?
- bountyhunter
21 Apr 2008 13:27
See if the part number is stamped on it. Check the part diagram at bike bandit and see what years that part number goes with.
- kxhonda
21 Apr 2008 14:05
I believe it is a 750 cylinder because the sleaves are almost touching, the 650 cylinders have more room between them. And it looks like an 8mm bolt hole in front of and behind the cam chain cavity. Just measure the bores to be sure. Standard bore for the 650 is 62mm and 66mm for 750. The 810cc kit takes it out to 69mm.
1977 Kz650B1 #576th made.
Warsaw, In
Warsaw, In
- steell
21 Apr 2008 18:35
Looks like a 80-81 750 cylinder block to me, it has the provisions for the roller cam chain of the earlier 650's. I have two that look just like it, one 81 and the other is a 80.
- gpzrox
22 Apr 2008 03:23
OK, so will this tach drive affect the bike physically if I put an 1980 head on my 84 GPZ?
Thanks.
Thanks.
- vach
22 Apr 2008 03:53
saaaweeet!! thanks!
- steell
22 Apr 2008 04:18
gpzrox wrote:
You'll just have to plug the whole for the tach drive.
If you need a 83-85 GPz750 head, I have two or three of them.
Thanks.
- gpzrox
30 Apr 2008 19:09
how would you plug the hole? Thanks!
