bad cylinder?????
- fibman
19 Apr 2008 08:54 #207578
by fibman
bad cylinder????? was created by fibman
I have a '81 kz750e We are trying to get it running good since it's been sitting for over a year, we are able to get it started but it needs wide open throttle to start and then it will die if you throttle down...also one exhaust pipe i think the #3 pipe(inside pipe on right side) will get extremely hot to touch almost right away but all the other pipes are still cold to the touch.
Any suggestions would be helpful...thanks.....
- BSKZ650
- Thank you received: 14
19 Apr 2008 08:58 #207581
by BSKZ650
77 ltd1000, current rider
76 kz900, just waiting
Replied by BSKZ650 on topic bad cylinder?????
sounds like it is running on one cyl,, what all have you done to the bike?
the key to getting one running that has been sitting is to do a full tune up and carb clean new plugs,ect.
- fibman
19 Apr 2008 09:06 #207582
by fibman
Replied by fibman on topic bad cylinder?????
We have checked all the fluids and changed the oil...check the gap on the plugs they looked pretty clean.
The next steps for this weekend will be to
1. clean the carbs
2. check the air filter
3. Possibly rebuild carbs(unsure how to sync them after tho)
4. follow any other suggestions...
1. clean the carbs
- MCH650SR
20 Apr 2008 08:45 #207811
by MCH650SR
1979 KZ650SR
modified with BS32 carbs
Yoshimura 4 in1
2006 Kawasaki Sherpa
1979 Honda CX500
BC Canada
Replied by MCH650SR on topic bad cylinder?????
I would get new plugs to try. If not new plugs, at least exchange the working cylinder plug into a non working cylinder. If the non working cylinder fires up and the previous working cylinder doesn't you know it's the plug. If the same cylinder fires up with the different plug but the others don't, you know you'll have to keep looking for the problem.
1979 KZ650SR
Yoshimura 4 in1
1979 Honda CX500
BC Canada
- mark1122
- Keep twisting it
- Thank you received: 109
20 Apr 2008 12:04 #207843
by mark1122
01 CBR600F4i Track bike.
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
Replied by mark1122 on topic bad cylinder?????
was it running ok before? wot start would suggest that it is running rich.do u have spark at each plug? do u have fuel at each carb?
Cobourg, Ont. Can.
~ ~ ~_@
~ ~ _- \,
~ (k) / (z)
- BSKZ650
21 Apr 2008 05:09 #207957
by BSKZ650
it blows my mind that people will want to clean plus,,, they dont make them like they used to, most of the time if you try to clean them you damage the electorde and cause it to not fire,, plugs are cheap put some new ones in, and have a spare set just incase
- JMKZHI
- Thank you received: 48
21 Apr 2008 05:17 - 04 Dec 2008 06:06 #207959
by JMKZHI
Replied by JMKZHI on topic .
del
Last edit: 04 Dec 2008 06:06 by JMKZHI.
