a nother Valve Shim Question
  • billkz750
  • billkz750's Avatar Topic Author
18 Apr 2008 19:17
#207475
if the valve shim is off or is two high will that make the cycl drop compression ?
  • Bluemeanie
  • Bluemeanie's Avatar
Re: a nother Valve Shim Question
18 Apr 2008 20:13
#207488
Sure it could, if the clearance is too tight it could cause the valve to not close completely, which could cause low or no compression. B)
