how to check oil when window is cloudy?
- elcid
- kawtoy
- Thank you received: 6
Harley Davidson- Turning gas into noise without the harmful affects of horsepower for over 100 years.
- jcote75
- Thank you received: 2098
... oil window is cloudy... will be cleaning it or changing the window....
For consideration, although shown as temporarily out of stock, here's a link to the new oil window offered by Z1E ---
Oil Window)
And recently, RRRR posted this info --
Last year as an experiment, I dumped an entire can of Seafoam into my 650's engine during an oil/filter change (subtracted amount of Seafoam from oil added so not to overfill) and ran it for 2K miles w/no clutch slippage or any other probs (I'm not gentle with the throttle either), and now I can actually see the oil level in the window!
My ZN700 had sat with extremely filthy oil left in it for 8+ years by it's PO, so I used the same "treatment" and got identical results....
Good Luck!
- jcote75
I'm in Canada and they seem to have a few in stock.
If you need to order one and not available in the US, I can buy one for you and send it to you if you needed.
- zbucket
- elcid
- roy-b-boy-b
- Thank you received: 103
- kawtoy
- Qdude
- It is all good.
77 KZ 650 C1.
77 KZ 650 C1.
- elcid
- PLUMMEN
- Thank you received: 104
