gpz 750 crankcase stud o-rings
- murphus
Richard
- bountyhunter
- Thank you received: 337
- murphus
Richard
- Mcdroid
- Gone Kwackers
- Thank you received: 317
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- bountyhunter
Head and cylinder removed. I know about the two o-rings between the head and cylinder at the outside edge, and the two o-rings between the cylinder and case at the outside edge. These are apparently as described, on the cylinder studs. It's possible I didn't notice them when I removed the cylinder and took it to be cleaned and machined. I don't have any proof they were ever there, and that's part of the question. Are they supposed to be?
Richard
I remember on mine, there are two "oil flow paths" from the crankcase top edge to the bottom edge of the cylinder (one on each side) and those MUST have new O rings or you won't get any oil pressure to the top.
As for O rings around the studs? Mine didn't have any. I had a round steel "knock pin" on the front left and right stud, no oil rings.
I have no idea why seals would be needed around a stud because there is no pressure run inside it, and the base gasket is what seals that surface from inside-out leak path.
I did see them in the picture, they are puzzling.
- bountyhunter
Richard
Eyeball the area around the stud: if an O ring is supposed to be there, it requires a 'channel" be milled in for the ring to sit in and expand into. If there are two flat surfaces coming together, an O ring can't go there because the ring would be obliterated.
